      May 2017
      MR 2 electric hydraulic power steering pump
      Anyone have experience using a electric/hydraulic power steering pump? (Second gen MR2 or early 2000s Mini)
      I have found some info primarily in the EV world. Looks like it could be a solution for my EcoBoost swap. The one question I have not found a answer to is has anyone out there been able to find a way to control the pump pressure relative to speed?
      Beach Park IL
      I looked into this briefly and it seemed like they draw a lot of amperage. It seemed the better option was to use the electric power module on the column.
      Donny
      May 2017
      Donny, that is true they use 75+ amp fuses and relays. I am told by the EV guys that the high amp draw is in parking or lock to lock situations. I have been looking at the Saturn Vue and Toyota units. I have a space problem under my dash.
      More research need
      Atlanta, GA
      Here's one of the best write-ups Ive seen on the MR2 pump-
      https://honda-tech.com/forums/road-r...edone-2528249/
      Pretty neat piece- uses a speed sensor to turn off at highway speeds and a stepper motor with integrated controls.
      I was also looking at using a Mercedes Benz electric pump too- Only used on the A-class (Euro )
      Mercedes Benz electric power steering pump-
      The electric pump is rated at 950PSI- I don't know the GPM of the M-B pump. Stock GM pumps ( C3 Corvettes for example) 2.9 GPM- where the upgraded pumps are around 3.3GPM (Chevy Astro Van pump)
      HOWEVER- after looking at all the options-
      I ended up using a fully electric motor on the column from a 2010-12 Nissan Cube- electronic controls are on separate module- but pretty much self contained.
      May 2017
      Thanks great info. I have looked at a install like yours. In my case the motor will sit under the Left side turbo. I have been told that is isn’t a good idea. Yours is relitively close to your exhaust have you had any issues and how long have you had it installed?
      Hey Richard,
      I see that you mounted the EPAS unit in the engine compartment. I've been doing a lot of reading on the various EPAS solutions and there seems to be some debate as to whether the electronic steering units can be used in a high heat/wet environment. All the OEM installations have the EPAS units under the dash. I'd like to do the same on my Cougar and I think it would be a lot easier to mounts the EPAs on the bottom of the column in the engine compartment. I already have 2 Toyota Prius units and the electronics.
      I just want to hear your thoughts on all that.
      1970 GTO Version 2.0
