      Jul 2016
      Holley power steering pump LS3, earls adapter# 961961ERL
      Hey guys, anyone know the sequence of parts when installing the Holley/Earls LS3 power steering adapter part# 961961ERL ?? The spring flew out with the valve when I was removing the original fitting, now I have to figure out which piece goes where with the new earls adapter. LOL
      Central CA USA
      Spring goes in first, then the flow valve, nut end towards the spring, then screw in the outlet fitting. The restriction in the fitting sets the flow rate. Your fitting is for a non-rack application, which is a higher flow rate.
      Jul 2016
      Thank you so much David. Holley told me the nut end in first. I hang up with Holley tech, and begin the install, Holley calls me back 5 min later at home and states they had it backwards LOL. Now I cant get the valve out because it went in first and backwards! SOB
      Sep 2018
      Sandy OR
      Hey David, was just installing this Earls fitting and saw your quote "Your fitting is for a non-rack application". I am running a DSE power rack. Are you saying I need a different fitting or do I eliminate the flow valve? Thanks in advance, Will
