Results 1 to 20 of 58
12-15-2017 #1Registered User
- Oct 2017
- 14
Project Corruptt - Ferrari powered 1968 Mustang
This is a 1968 Mustang I started building almost 10 years ago and am now finally going to finish. It has quite a few modification I previously did such as ridetech air suspension (which will need some updating) shaved cowl vent, door handles, emblems etc. made a trunk spoiler that is laid down, made quarter extensions out of steel and incorporated into the body as well as the rear bumper. Started on the ground effects and most noticeable chopped the top. The car is currently at The media blaster so we can continue the modification necessary to install something a little different under the hood. What we will be running is a Ferrari V8 that will receive a set of turbos as well.
12-15-2017 #2Registered User
- Oct 2017
- 14
Here is the engine. F430 based but will have quite a few custom touches to make it operate correctly in its new home. Will be running a Ferrari California intake manifold to locate the throttle bodies correctly in a front engine application. Will be runnig Ls 92MM throttle bodies
12-15-2017 #3Registered User
- Oct 2017
- 14
There is quite a few components that will need to be designed to make this all work. We will be runing a t56 behind the Ferrari v8 so adapters will need to be made. Everything is being designed in CAD to ensure accuracy
Attachment 147033Attachment 147034
12-15-2017 #4Registered User
- Oct 2014
- DFW, Texas
- 422
