    Results 1 to 20 of 23
      Jun 2010
      Deployed
      VaporWorx Pressure Location Ideas?
      Gents, I need some ideas on where to locate the pwm fuel pressure sensor. I have seen some ideas on Google, but I don't like the erector set type set-up with a handful of AN elbows. It also seems too heavy to just hang off the tube. What have you all done?
      1970 Camaro/DSE build
      Mountain Springs, Texas
      I’ve done several using the elbows etc supplied by Carl. Works fine. I install the DSE fuel pump access panel in the trunk floor and it makes everything accessible and serviceable.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jun 2010
      Deployed
      Don
      Do you have pics of your set-ups?
      No pics. But there is nothing unique about them, I just used the parts Carl supplied.
      Don
      Jun 2010
      Deployed
      Don
      He didn't supply any parts
      They are here. You have to order them.
      https://www.vaporworx.com/product-ca...-and-hardware/
      Don
      Newbury Park, CA
      Depending upon the tank design, oftentimes the best place to put the sensor is just downstream of the pump so that the sensor lays in the recess of the tank. This helps to protect the sensor plus makes for a clean installation since the sensor is not visible. The access door is handy in many cases, but fortunately the reliability of the fuel modules is very good so either method should work well.
      To me the entire automotive aftermarket plumbing market is in flux. The go-to AN system works quite well and is very robust, however, the GM quick-connect system is also quite robust and reliable. There isn't a full line of compatible fittings that make interchanging between one and the other as easy as it should be, or stand-alone hose fittings that would make life easier. I've begged several companies to please start making something like this, but my feeling is that if they go down that road it obsoletes current manufacturing models.
      Jun 2010
      Deployed
      do you have any pictures of setups of the fuel pressure sensor plumbed to the pump. I have vaporworks ricks tank with the recess
      I will ray to get you a pic of my wife’s car in the next day or so. Just need to remove the screws on the access cover.
      Don
      Don
      Here is a pic of my wife’s car. Excuse the dust, we live on a dusty gravel road and the car is driven...
      Newbury Park, CA
      Sorry I missed this one but Don has it laid out well. If using a 90* F-F swivel often the fuel line hits the side wall of the recess. The 90* can be reduced a but by unbending to tuck the line in a bit. I use the 45* unmodified.
      Newbury Park, CA
      It is also not recommended to mount the fuel pressure sensor in the fuel rail. The problem with mounting the sensor in the fuel rail is that the injectors, as they open and close, create pulsations that the vaporworx system will chase. In other words, the system can react fast enough to chase individual injector pulsations. The result is a wildly varying fuel pressure at idle. GM has the sensor mounted near the pump outlet on many cars for the same reason.
      Just used a pressure tap union.
      Jul 2011
      Nashville/ Tampa
      So what would be the best way to do this if we wanted to use the factory style nylon fuel line?
      Edit - it looks like putting one of these on the fuel pump outlet for the pwm and another on the fuel rail for the pressure gauge might work? Then run nylon line between them perhaps? If that works it would mean one nice long uninterrupted line from front to back.
      https://www.summitracing.com/parts/aei-15121
      https://www.instagram.com/gen_v_lt1_chevelle/
      Do not buy anything from Frankie's Used Auto Parts. Ever.
      Chevelle ̶a̶l̶m̶o̶s̶t̶ ̶f̶i̶n̶i̶s̶h̶e̶d̶ L92/200-4r now Gen V LT1 and T56- https://ls1tech.com/forums/conversio...nvertible.html
      Jun 2010
      Deployed
      I thought about doing it like “alocker” but I did not want weight of the sensor and harness resting on the nipple if the fuel pump. Vibration and bouncing of the car doesn’t seem good. I put mine here. Plenty of support and looks better then the erector set of AN fittings.
      Jul 2011
      Nashville/ Tampa
      That looks fairly simple, did you bend and flare that initial segment yourself?
      Jun 2010
      Deployed
      ^^ Yes I made the whole line from straight tubing. Used a Ridgid flaring tool and a basic tube bender.
      Jul 2011
      Nashville/ Tampa
      That aeromotive piece came in, it's going to go on the fuel rail end for now until I run pwm (then I'll get another to put where this one is in the picture).Name:  39206886435_4d6bcfffdc_z.jpg
      Jul 2013
      N. Scottsdale
      I'm in the process of mocking up my fuel system and wondering what set-up would work better. Option A is to come off the ZL1 module with 6AN and starting the 8AN line to the engine after the fuel pressure sensor. Option B is to come off the fuel module with 8AN (assuming there is a 3/8 quick connect to 6AN male adaptor available and an 8AN fitting for the fuel pressure sensor) so that the line size is consistent throughout.
      NJ
      What kind of power are you making? If you're running the Gen 5 ZL1 pump, 6AN will be enough to support the max that pump will put out. That's what Carl told me when I bought his set up. Heads/cam LS7, aiming for 630-650whp.
