    Page 12 of 12 FirstFirst ... 2 7 8 9 10 11 12
    Results 221 to 232 of 232
    1. #221
      Gauges look great Joe. You do nice work.
    2. #222
      Oct 2011
      Thanks guys! I was really worried that the 2 1/16Ē gauges wouldnít fit in the space. But they did with zero space left. Crazy how things work out sometimes. Yes they are speedhut gauges. They say on their website it takes 5 weeks, but I received them in less than 3 even with custom printing.
      I also used the stock zl1 intercooler pump and bracket. Itís a really well made piece because of the rubber surround, the pump is basically floating in rubber, when the pump is on it transmits zero vibrations. Anyway, I mounted it on the drivers side frame. Hereís some pics for reference. I believe I had to reclock the pump on the bracket so that it could face in the direction I wanted.
    3. #223
      May 2008
      Merewether
      Country Flag: Australia
      Loving the MB interior and the drivetrain choice.
    4. #224
      Apr 2007
      New Jersey
      Perfect. Thanks for the info
      Doug L.
      68 RS/SS Conv. DSE/Ridetech and LSA/T56 rebuild in progress
      67 RS Coupe LS2/T56 named "NutKse"
    5. #225
      Those gauges look killer man! I love your out of the box thinking with that. It looks like a modern interpretation of the 67-68 gauge surround. Can't wait to see more.
      1968 Camaro 6.2 w/ LSA, TR6060-Magnum hybrid, Z51 brakes, 12 bolt, Speedtech, Hotchkis, DSE
      1976 T/A LS1, 6 Speed, C5 front brakes, and etc. SOLD
    6. #226
      Oct 2011
      Thanks Ryan! I agree, itís all coming together and really looks like it all belongs. The new Mercedes interior design is very retro.
    7. #227
      Oct 2011
      I also ordered some turn signal indicators to go in the cluster:
      Alpinetech PLB12MS 12mm 1/2" 12v LED Metal Signal Indicator Pilot Dash Light (Single Arrow (Green)) https://www.amazon.com/dp/B07D8G1VZJ...G7W9YCRA6SZY58
      High beams:
      Alpinetech PLB12MS 12mm 1/2" 12v LED Metal Signal Indicator Pilot Dash Light (High Beam Indicator) https://www.amazon.com/dp/B0722Q4Q7H...2KYCK2C4PGNKPH
      And of course a check engine light:
      Alpinetech PLB12MS 12mm 1/2" 12V LED Metal Signal Indicator Pilot Dash Light (Check Engine) https://www.amazon.com/dp/B07D848HV1...YX64P0E0TPQ7FW
    8. #228
      Oct 2011
      Not much of an update, but I have been wrapping up all the wiring. I also finished the gauge pod. It came out great. Iím super happy with it. Looks very oem.
      I think Iím going to have the interior guy come make door panels, recover the dash and glue in the iPad holder so that they will be all ready after the car gets painted. I also donít want anything to get scratched. I know most people do interior last so we will see what the interior guys say.
    9. #229
      That looks great man! I loved the Speedhut gauges that I had in my 1976 T/A, and they look right at home in that cluster. Do you plan on using those butt crimp terminals or is that for testing? If you were planning on using those butt terminals for good, I'd suggest using non-insulated seamless barrel terminals with a high quality shrink tube instead. Or better yet, do something like a Delphi GT 150 connector so that you can quickly disconnect if needed.
    10. #230
      Oct 2011
      I was planning to use them for good. They are only in turn signal, high beam and Check engine light. Why do you not recommend them?
    11. #231
      X2 on those butt connectors. They can be unreliable. Non insulated seamless with high quality sealing heat shrink is the way to go as recommended above. Or a quality connector.
    12. #232
      Nov 2018
      Winchester, KY
      Just now zipped through your project and about the same time started on mine, and you definitely went deeper and more creative! Cool!
