    Page 12 of 16 FirstFirst ... 2 7 8 9 10 11 12 13 14 15 16 LastLast
    Results 221 to 240 of 305
    1. #221
      Mountain Springs, Texas
      Gauges look great Joe. You do nice work.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
    2. #222
      Oct 2011
      Thanks guys! I was really worried that the 2 1/16” gauges wouldn’t fit in the space. But they did with zero space left. Crazy how things work out sometimes. Yes they are speedhut gauges. They say on their website it takes 5 weeks, but I received them in less than 3 even with custom printing.
      I also used the stock zl1 intercooler pump and bracket. It’s a really well made piece because of the rubber surround, the pump is basically floating in rubber, when the pump is on it transmits zero vibrations. Anyway, I mounted it on the drivers side frame. Here’s some pics for reference. I believe I had to reclock the pump on the bracket so that it could face in the direction I wanted.
    3. #223
      May 2008
      Merewether
      Country Flag: Australia
      Loving the MB interior and the drivetrain choice.
    4. #224
      Apr 2007
      New Jersey
      Quote Originally Posted by joeko23 View Post
      Perfect. Thanks for the info
      Doug L.
      68 RS/SS Conv. LSA/T56.
      67 RS Coupe LS2/T56 named "NutKse"
    5. #225
      Sep 2009
      Those gauges look killer man! I love your out of the box thinking with that. It looks like a modern interpretation of the 67-68 gauge surround. Can't wait to see more.
    6. #226
      Oct 2011
      Thanks Ryan! I agree, it’s all coming together and really looks like it all belongs. The new Mercedes interior design is very retro.
    7. #227
      Oct 2011
      I also ordered some turn signal indicators to go in the cluster:
      Alpinetech PLB12MS 12mm 1/2" 12v LED Metal Signal Indicator Pilot Dash Light (Single Arrow (Green)) https://www.amazon.com/dp/B07D8G1VZJ...G7W9YCRA6SZY58
      High beams:
      Alpinetech PLB12MS 12mm 1/2" 12v LED Metal Signal Indicator Pilot Dash Light (High Beam Indicator) https://www.amazon.com/dp/B0722Q4Q7H...2KYCK2C4PGNKPH
      And of course a check engine light:
      Alpinetech PLB12MS 12mm 1/2" 12V LED Metal Signal Indicator Pilot Dash Light (Check Engine) https://www.amazon.com/dp/B07D848HV1...YX64P0E0TPQ7FW
    8. #228
      Oct 2011
      Not much of an update, but I have been wrapping up all the wiring. I also finished the gauge pod. It came out great. I’m super happy with it. Looks very oem.
      I think I’m going to have the interior guy come make door panels, recover the dash and glue in the iPad holder so that they will be all ready after the car gets painted. I also don’t want anything to get scratched. I know most people do interior last so we will see what the interior guys say.
    9. #229
      Sep 2009
      That looks great man! I loved the Speedhut gauges that I had in my 1976 T/A, and they look right at home in that cluster. Do you plan on using those butt crimp terminals or is that for testing? If you were planning on using those butt terminals for good, I'd suggest using non-insulated seamless barrel terminals with a high quality shrink tube instead. Or better yet, do something like a Delphi GT 150 connector so that you can quickly disconnect if needed.
    10. #230
      Oct 2011
      I was planning to use them for good. They are only in turn signal, high beam and Check engine light. Why do you not recommend them?
    11. #231
      X2 on those butt connectors. They can be unreliable. Non insulated seamless with high quality sealing heat shrink is the way to go as recommended above. Or a quality connector.
      Don
    12. #232
      Nov 2018
      Winchester, KY
      Just now zipped through your project and about the same time started on mine, and you definitely went deeper and more creative! Cool!
    13. #233
      Oct 2011
Size:  429.9 KBName:  E1018494-4AEF-4B01-A40C-89AA54E62404.jpg
Size:  463.6 KBFinally found a painter. She’s all put together, just waiting for my turn.
    14. #234
      NJ
      Who did you wind up going with?
    15. #235
      The gauges look great! Congratulations on finding a painter.
    16. #236
      Oct 2011
      Thanks guys! Here’s the gauges mounted and the color scheme of the interior I’m going for. I also a ordered the BMW 4 series door panels so the interior guy can utilize the door pulls, door handles, trim, speaker grills, etc.
Size:  355.9 KBName:  F4AAF5E3-CE90-4FAB-ACF6-F4D32CC9D56F.jpeg
Size:  633.7 KBName:  FD143B4D-99C3-4880-A4B9-DB130975A4DD.jpeg
    17. #237
      Sep 2017
      What’s the correct orientation of the inner wheel well supports?
      This is drivers side outside:
      Attachment 189696
      This is passenger side outside:
      Attachment 189695
      Is the bracket supposed to mount to the outside of the firewall support (facing tire) or the inside firewall support (facing engine)?
      I thought the same thing when mine return to from paint shop because I didn't know. Los correct and your build is awesome.
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    18. #238
      Oct 2011
      Quote Originally Posted by TANKMASTERJ View Post
      Jason
      Thanks Jason! The orientation is so weird, once you get the inner fender on, those bolts are inaccessible from the drivers side. Why would they do that?
    19. #239
      Sep 2009
      Killer job on the interior man. The custom stuff is so nice.
    20. #240
      Oct 2011
      As I impatiently wait for my car to be painted, I took a look at the side mirror again, everyone who sees them says the same thing. They are too big for the car. So my hunt continued. I just fit these, they are out of a 18-21 Camry. They are smaller than the Lexus ones I had and seems to look more aggressive as well. I also like that they have little dimples on them, again look more aggressive. What do you guys think?
      I also ordered a set from a Corolla and a Chevy Cruze, they should be coming in by the end of the week.
      Let me know your thoughts.
Size:  317.4 KBName:  4AA41085-EAD0-4751-911E-3DC38A27439C.jpg
