    Page 11 of 11 FirstFirst ... 6 7 8 9 10 11
    Results 201 to 216 of 216
    1. #201
      Oct 2011
      Don, I tried to prevent air bubbles by filling through the upper radiator hose that way the block gets coolant first and pushes out any air bubbles through radiator as it rises. I will also try your method of raising the front higher than the rear and squeezing the upper and lower hoses.
      What coolant temp should I be shooting for? I have the stock 190 deg thermostat. I read that normal operating temps on ZL1s hover between 200-210. That’s basically what I had.
      Also after I shut the engine down the fans kept spinning and slowly came to a stop, I know that’s normal but they were making a high pitch sound. Is that normal? Or the high pitched sound is because my fans were running in reverse?
    2. #202
      With a stock thermostat that temperature is fine imho. It sounds like you filled it correctly so there should not be any air in your system. If it starts running hot then you could try purging it.
      The whining sound is due to the PWM speed control of the fans. It’s nothing to worry about.
    3. #203
      Oct 2011
      Thanks Don, can’t wait to rip it around the block. I’m surprised how well it runs on the base tune. I changed supercharger pulley to 2.38” and I have 72lb injectors.
    4. #204
      Congrats!! What an amazing feeling. That's amazing that someone that sold something online was actually honest!
      1968 Camaro 6.2 w/ LSA, TR6060-Magnum hybrid, Z51 brakes, 12 bolt, Speedtech, Hotchkis, DSE
      1976 T/A LS1, 6 Speed, C5 front brakes, and etc. SOLD
    5. #205
      Oct 2011
      I know I was super surprised it has such low miles!
    6. #206
      Oct 2011
      As promised, I bolted in the seat and took it for a drive up/down the block a few times. All I can say is WOW! The car handles sooo good! Everything is so tight. No rattles, no shakes, suspension is tight but not stiff. I set the rear single adjustable shocks at their middle setting. The front double adjustable I set at 4 clicks rebound and compression which is about 1/4? Anyway the ride is supple almost like my wifeís Range Rover Sport. Iím super happy how the car rides/drives so far. Any blip of the throttle smokes the tires fairly easily!
      I need to raise the rear about 2 inches I think. Seems a little low to me. What do you guys think?
      Also the power steering is VERY intermittent. Even though I turned the wheel back and forth a million times it still probably has air in the system. I ordered a vacuum pressure bleeder for power steering so hopefully that get all the air out.
      After the first start video I posted I decided to scan the ECU for trouble codes and of course there was a code for p0206 code for injector malfunction and code for coil C misfire. Luckily, both seem like easy fixes. The injector plug wire came loose, so I took apart the plug, soldered on the wire and cleared that code. For the misfire, I unplugged the coil for cylinder 3 and noticed the plug had a crack in it. So I ordered a new plug/connector, hopefully that will solve that problem.
      Enjoy the video!
      https://m.youtube.com/watch?v=jgJ675Ql0T0
    7. #207
      Jun 2012
      Golden Valley AZ
      That is so awesome!!! Good to know that Heidts stuff rides nice. OK, now I need to get off here, and go work on mine!!! Oh, wait, it's 103 today, I think I'll stay in the house..hahaha
      John Rodko
      69 RS/SS Camaro.
      Heidts Pro G IRS w/ 3:90 gear, Heidts Pro G front
      6.0L LQ4 to be TT
      6 speed or 4L80E, that is the question..hmmm
      Future plans for full TMI interior
    8. #208
      Oct 2011
      Quote Originally Posted by Rodknock View Post
      Getíer done John!
    9. #209
      I think the stock LSA power steering pump has too much pressure for the rack. You may need to reduce the pressure if you have not already. I ended up with a pump from Turn One that they set up for me. Did you cycle the steering rack without the car running to purge the air?
    10. #210
      Oct 2011
      I bought this pressure reducing fitting from Turn One, chassisworks recommends 1-1.5 gpm. I bought the fitting that’s 1.3gpm. So I’m assuming all should be well.
      Yes, I turned the wheel a million times back and forth with engine off, I also jacked up the front end like you suggested with the radiator. I saw some YouTube videos of tech updates that the new pumps have very small cavities which make it nearly impossible to bleed just by turning the wheel back and forth. Vacuum bleeding several times is what’s recommended so that’s what I’m going to try.
      https://turnonesteering.com/product/...cts-v-zf-pump/
    11. #211
      That sounds really nice and tight! So glad to hear you had it out around the block. Aren't LSA motors great!
    12. #212
      Oct 2011
      They sure are Ryan! I had a 13 ZL-1 one of the best cars Iíve ever owned. It was comfortable, fast, reliable, everything Iím hoping my build will be.
    13. #213
      Oct 2011
      What’s the correct orientation of the inner wheel well supports?
      This is drivers side outside:
      This is passenger side outside:
      Is the bracket supposed to mount to the outside of the firewall support (facing tire) or the inside firewall support (facing engine)?
    14. #214
      The two sides are different and it looks like you have them correctly installed. At least that is my recollection.
    15. #215
      Oct 2011
      I took a look at the assembly manuel yesterday, and you’re correct as always! So weird that driver side bolts go from exterior to interior. But on the passenger side they go from interior to exterior. I surely thought I was doing something wrong.
    16. #216
      Oct 2011
      I’ve been battling with the power steering pump for over a week. It’s been VERY intermittent and seemed like when the fluid heated up, I would lose power. All my research pointed to air in the system. I bought a vacuum bleeder and the same thing would happen. I decided to call chassisworks about the rack because the pictures of their rack on the website looked different than mine so perhaps I wasn’t getting enough assist. After speaking with them they basically said probably still have air in the lines. Then I called turn one who was a tremendous help. I explained what was happening and the tech guy said it sounds like the valve in the pump is sticking so he recommended replacing the pump.
      So today I received the pump, vacuum bled the system and took a spin up and down the block and FINALLY all was well. I was really worried that these mustang style racks would feel over assisted or lacked feeling. I am very happy to report that the steering feels tight, accurate and totally not over assisted. In fact it feels very close to a 3 series BMW I had, where you needed a little bit of muscle to turn the wheel.
      I also installed the Raingear hidden wiper system, very good, high quality kit. Everything bolted into place easily and the wiring seems pretty simple as well.
      My next order of business is installing the AAW harness and getting all the electronics sorted. I also ordered a 12v-5V converter to keep the BMW M4 seats constantly alive as they timeout after about 30 sec. This is the converter:
      12v to 5V DC Converter Car Power Voltage, Waterproof DC 6.3-22V 12V Step Down to DC 5V 3A 15W Voltage Regulator Buck Converter Power Supply Step-Down Module Compatible with Vehicle Car Truck Volt https://www.amazon.com/dp/B07Y2V1F8V...FJHYCS81BR5PPA
      I also ordered a converter for the iPad and phone charger:
      JZK Car Power Converter DC 12V to 5V/ 3A Voltage Converter with Dual USB Adapter Connectors for Phone Charging car Audio Radio etc https://www.amazon.com/dp/B06XSCCLCD...5V79EPF9SGJX73
