      Mar 2015
      FL
      EFI parts: Pro-M 85mm GM MAF for carb style TB, 30# fuel injectors, Tweecer RT
      GM 85mm MAF sensor, Pro-M Racing Stage 1 On Throttle Body Mass Air Meter
      Pro-M Racing Stage 1 On-Throttle-Body Mass Air Meter
      Asking $129 shipped.
      This is a modified GM 85mm MAF sensor on top of a custom machined Al base that allows the sensor to be placed on top of a carb style 4-barrel 1000cfm throttle body. It sits on top of the 4 by 1.75" throttle body inside of the carb style air cleaner. It has the five pin plug that includes IAT sensor (two pins for IAT and three for MAF).
      This will wire into an LS engine harness if:
      1) for some reason you've converted your LS to a carb style manifold and 4x1.75" barrel throttle body and conventional air cleaner.
      2) Or if you are using an LS ECU to control a V8 with carb style EFI manifold and 4x1.75" barrel carb style throttle body and conventional air cleaner.
      For Corvette, GTO, CTS-V, Z06, LQ4, LQ9, LS4, L92, LS3, LS2, LS1, G8, L76, L92, 6.0, 6.2 etc etc ECU's
      If you have the Mass-flo or Pro-M system on your V8 engine this can be used if you are using the carb style EFI manifold and 4x1.75" barrel throttle bodyand conventional air cleaner.
      Intended for Pro-M racing EFI systems for early model V8's. Only thing it needs is a Frequency to Voltage converter from Pro-M.
      Pics below.
      SOLD -- Tweecer RT with 5 position Switch and wires
      PICS: GM 85mm MAF sensor, Pro-M Racing Stage 1 On Throttle Body Mass Air Meter
      -Mitch
      G8 GXP, White Hot, Auto, bone stock
      68 Firebird, 428 Pontiac, CNC'd KRE Al d-ports, hyd roller, EFI, TKO600, TCI Eng complete chassis, Ridetech, Kore3 C6Z brakes, C5Z 18" with 315 rivals x4, C6zr1 mufflers
      RRR, NASA HPDE https://youtu.be/DPp1l9-FuNE
      Mar 2015
      FL
      Price drop.
      -Mitch
      Mar 2015
      FL
      Price drop.
      -Mitch
      Mar 2015
      FL
      Price drop. Still available.
      -Mitch
      Jul 2008
      Chicago
      Is this still available?
