    Results 1 to 8 of 8
      Oct 2009
      Ithaca, NY
      Retrofitting a 2015 Mustang Power Seat
      Got a power seat out of a 2015 Mustang on recommendation from another forum (don't remember which one) that said the Ford seats were easy to install, as all they needed was 12v.
      Well, of course, it's easier said than done. Anyone retrofit a 2015 Mustang power seat into their car? If so -what are the wiring connections?
      Apr 2012
      Woodstock, IL
      SchwartzPerformance
      Oct 2009
      Ithaca, NY
      Beautiful. Now, my seat is a memory seat with the DSM (Drivers Seat Module). Is there any chance of getting this to work? Seems like I would have been much better off getting a seat without memory, as the switches are direct wired.
      Oct 2009
      Ithaca, NY
      Anyone use this seat?
      Jan 2018
      Saint Louis, Missouri
      If the seat has the memory module and you are not wanting to retain this and the seat is wired with an original low amperage switching, I have before in the past used existing switches once I've identified what wires connect and disconnect from each other in the different switch positions and then wire the switch to aftermarket relays to then send the proper power/grounds to the seat motors. When I have done this I have to use a meter to verify things on the switch but the switches wiring cannot be connected to anything else or you might get the wrong readings.
      Jim
      Oct 2009
      Ithaca, NY
      Well, I had to give up on the original seat that I bought. I found a vendor willing to trade me my memory lower seat track for a non-memory seat track. Did the swap, and now it's a simple 12v connection to get the seat to move. LESSSON LEARNED: Do not use memory seats in a classic.
      Oct 2009
      Ithaca, NY
      Quote Originally Posted by ProTouringCuda View Post
      Now, I'm trying to get the climate controls to work. Has anyone got any experience wiring these up?
      Mar 2015
      I'm currently in the process of wiring up some Cadillac CTS seats. The driver's seat has memory but in the schematics you can simply disregard the 4 wires that pertain to the memory functions. All 5 of the electric motors have potentiometers on them but can either simply be disregarded or taking off as it is for the memory.
