    Page 1 of 9 1 2 3 4 5 6 ... LastLast
    Results 1 to 20 of 161
      IN/MI border
      Buddy P's 1971 Camaro build
      Ok, little late starting this new build thread but here it goes.... Sold the '68 last fall and picked up a '71 roller. It was in project stage and looked smooth and straight. Long story short there was quit a bit of shoddy workmanship on this thing. So went into complete teardown mode. Project started mid Nov. 2016. Took down to bare shell, sandblasted and installed new floor, new trunk pan, new tail pan, new trunk drop offs and fixed several other misc areas. From there I got into some custom work...
      Day I brought it home
      Floor was originally covered with parts and dynamat, once uncovered it was clear someone had replaced majority of the floor from a donor car. They cut new piece too short and used 1" wide sheetmetal to connect them. Look at that nice straight tunnel...
      Floor cut out...
      After sandblast
      Bottom of tail pan... 3/8" thick bondo. Completely removed tail pan
      Uncovered several layers of patches over patches in trunk, completely removed trunk pan
      Removed inner fender wells to prep for mini-tubs
      Inner rockers were tore up from previous floor hack job. Had to restore both inner rockers
      New full floor pan, full trunk pan and tail pan installed
      Modified and boxed in the rockers. Had new rocker formed and fabbed end closures
      Carried the "skirt" look to bottom of rear quarter
      Modified tunnel for clearance for future T56 Magnum
      IN/MI border
      DSE Quadralink, Subframe connectors and Mini-tubs
      Installation of DSE subframe connectors
      Added channels along subframe connectors for parking brake cable routing. May use for brake and fuel line routing as well
      DSE mini tub installation
      DSE Quadralink bracket installation
      And back to that previous shoddy workmanship... inner quarter panel on pass side was beat to crap from previous people attempting to install outer wheel well. I removed and replaced the inner quarter and outer wheel well prior to mini tub installation on this side.
      Smoothed firewall
      Fabbed up a fuel pump access door in trunk floor
      More parts arrived... C&R radiator with integrated oil and PS fluid coolers - Thanks from TDS-Kreations
      Decided on Sparco Chrono Road seats for my larger 6'-3" frame. Had to order early to use for clearance when getting cage installed.
      While car was out of shop getting cage installed I refurbished the original tilt column. Washed out and repacked bearings, fresh paint and added NRG hub adapter and steering wheel quick release. Also replaced levers with new billet levers..... I don't ever want to pull one of these apart again
      Got car back in shop after having 6pt cage with removable harness bar installed
      Some of the little things... had to cut down humps in floor under seats for seat lever clearance to allow me to get seat as low as possible in the car.
      IN/MI border
      Underbody is now complete, took it to the local Line-X shop and had the underbody sprayed with bedliner spray. Did this with my old '68 as well and it turned out nice so did it again on this one.
      Added some brackets in the trunk area to accommodate a spare... just trying to think ahead. The plan is to have a full size spare (not the donut in the photo) and have it strapped down to the brackets.
      Jun 2014
      Highland Village, TX
      Wish I had a little of that kind of Talent. Awesome looking work.
      Ron -
      1970 Mach1
      440 RWHP, 428 RWTQ
      Calypso Coral, 357W, T5Z 5-speed,
      Edelbrock 454 17x8 Wheels, 255x40x17 rear, 215x45x17 front, Bridgestone Potenza RE-71, TCP Coilovers Front, Global West Del-A-Lum Bushings,Global West Adj. Strut Rods, Wilwood Discs All around
      IN/MI border
      Thx, Just learned from doing... went in blind when I built my '68 previously
      IN/MI border
      Some other recently purchased parts going into the build with help from TDS-Kreations, Bowler Transmissions and Miller Built USA
      DSE 9" Ford housing and installed an aluminum Strange third member
      Miller Built Hybrid Floater system for rear end... bought this kit for the '68 with 12 bolt rear and had great results so bought 2nd kit from Jay. Great customer service.
      McLeod RST twin clutch kit, throwout bearing and Bowler billet shift handle
      T56 Magnum from Tom Farrington at TDS-Kreations and Bowler Transmissions
      IN/MI border
      Also started on motor with help from Jason Mitchell at Precision Wiring and Performance... LS3 base with cam and valvetrain upgrades for LSA supercharger. Anybody looking to get a Cam, valvetrain upgrades or vehicle harness and wiring Jason is a good go to guy.
      IN/MI border
      And now the latest update as of today, picked up DSE hydroformed subframe with help of Dutchboys Hotrods. Now to line up and install subframe and rear end and set this car on the ground
      Fantastic start to a project, love what you are doing! Looks like the car is coming along great. Keep up the work and it will be done in no time.
      Jonesboro, Arkansas
      Buddy,
      Do you paint the underside of the car to match the exterior or leave the bed liner surface? Just curious. Looks like you've got a heck of a start, I know it'll be great!
      Carl Wilson
      Sep 2011
      Southern Ontario
      Very nice work! What benefits [aside from looking great] do you get from the LineX?
      IN/MI border
      Quote Originally Posted by minendrews68 View Post
      Buddy,
      No I'll leave it as you see it. Thanks, yes pushing hard on this one
      Yes looks great, but also extremely durable for a driver/track oriented car, seals up the underbody and acts as sound deadener. I will not use Dynamat on the interior (little bit of cost trade off)
      Dec 2008
      Detroit
      Very nice! Loved your '68, so i'm following along. Wish the Miller Built stuff was available back when I bought my Moser floater, I probably would have gone that direction....
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      IN/MI border
      Thanks! Yeah the Miller Built floater is a nice setup. I never thought to look at Allstar for a fuel access panel, I like that one you have.
      Dec 2008
      Detroit
      Quote Originally Posted by BuddyP View Post
      Thanks... I guess we all learn from each other because I like the way you welded the frame in for your panel. When I pull my body off to paint, I'm going to weld mine in.
      Chris--
      Apr 2010
      Great work. I'm so glad i stumbled upon this thread. DSE makes great stuff. $$$$$$$$. How much did the Line x undercoating cost? I like that idea.
      Subscribing.
      Nice work Buddy, I watched the 68 build and I'm already impressed with this one. I love the LineX on the bottom, I wish I had gone that way with mine. As far as using LineX and not the Dynamat I think your better off with this, I bet you'll save some weight too. Love the build.
      IN/MI border
      Quote Originally Posted by Jimbo1367 View Post
      $500
      Thanks! I had both on the '68 I did and I think it was overkill, especially after you add carpet and padding. Just doing carpet and padding with this one. Yes Dynamat is heavy.
      The Netherlands
      Country Flag: Netherlands
      impressive!! I will be watching this build for sure :-)
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
      Apr 2010
      BuddyP,
      Thanks. Badass build !!!
