Results 1 to 12 of 12
04-04-2017 #1Registered User
- Aug 2008
- 59
Help me pick a rear gear for my 68 camaro.
So I am deep into a rebuild in my 1968 Camaro. I have the body tub off the subframe and we're doing the sheetmetal work and getting every last square inch of rust blasted, cut, or sanded off, including up in the cowls.
I have decided on doing an aluminum GEN IV 5.3L block with Darton sleeves and a 454 rotating assembly and some CNC LS7 heads. I want to run this motor through a T56 magnum tranzilla. This car is for the street. I am not a drag racer, or autocrosser, but I do enjoy whipping my 2014 Z51 C7 around corners. So I just want an all around fun car with serious grunt. I imagine the combo I pick for this engine will make similar HP/Torque as a 2016 Z06, probably with the torque curve shifted up a bit. I will probably go with either CA 4 link rear or a torque arm for traction out back. I thought the final drive ratios of the Z06 might be an appropriate place to pick gears, because I don't want first gear to be useless:
Z06:
2.29
1.61
1.21
1.00
0.82
0.68
0.45
3.42 Rear.
Final drives for each gear:
7.8318
5.5062
4.1382
3.42
2.8044
2.3256
1.539
The tranzilla I want to go with has the following gears:
2.66
1.78
1.3
1
0.74
0.5
So here are the final drives for the following rear gears:
3.42 rear:
9.0972
6.0876
4.446
3.42
2.5308
1.71
3.23 rear:
8.5918
5.7494
4.199
3.23
2.3902
1.615
3.08 rear:
8.1928
5.4824
4.004
3.08
2.2792
1.54
2.73 rear:
7.2618
4.8594
3.549
2.73
2.0202
1.365
So I was thinking either a 3.08 or 3.23 rear gear. Am I off my rocker on this? I don't intend to do full drag race launches at 4K rpm, just want to be able to gun it off the line and have it pull hard without going completely sideways with the slightest tap in first.
