    Page 4 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 ... LastLast
    Results 61 to 80 of 232
    1. #61
      Jan 2012
      Newton, KS
      On the rotisserie so the IRS K frame can be welded in:
    2. #62
      Jan 2012
      Newton, KS
      Second segment of the tunnel has been welded in. A bezel (seen in bottom right corner) is in process which will have a groove all the way around; carpet will fit into the groove.
    3. #63
      Jan 2012
      Newton, KS
      After having the Roadrunner dash powdercoated, I changed directions and bought a 1968 Charger Rallye dash frame off one of the facebook trader pages for $100 plus shipping. Here it is in place:
      I also picked up a set of Dakota Digital gauges.
    4. #64
      Jan 2012
      Newton, KS
      IRS getting welded in
    5. #65
      Jan 2012
      Newton, KS
      Tunnel from below
    6. #66
      Jan 2012
      Newton, KS
      Tunnel and tunnel cover/closeout
    7. #67
      Apr 2014
      Great job grafting in the IRS! very cool!
      Pat
    8. #68
      Maybe I missed it, but is it a stock IRS? From what vehicle?
      Instagram @projectgattago
      Dr. EFI
    9. #69
      May 2013
      Colton Ca.
      In one of his posts he says he parted out a few SRT8s and had parts laying around. I assumed srt8 rear? Could be wrong tho.
      Ahmad B.
    10. #70
      Jan 2012
      Newton, KS
      Quote Originally Posted by Build-It-Break-It View Post
      I've parted out 50+ SRT8's so yes it was an SRT IRS. In hindsight, Matt said he would probably design his own IRS since modifying the IRS work has been a lot more effort then planned!
      - - - Updated - - -
      Quote Originally Posted by keepat View Post
      Pat
      Thanks Pat!
    11. #71
      Jan 2012
      Newton, KS
      Inner wheel tub time! The inside edge of the inner tub was cut out on both sides. I new AMD inner tub will be welded in. In essence, this does the same job as adding the widening strip, which can be purchased.
    12. #72
      Jan 2012
      Newton, KS
      I love the look of the modified housings
    13. #73
      Dec 2015
      I really love your build. You've done some really nice fab work getting the IRS in there! Keep up the updates. I think that finishing this car will help get your Cuda finished, as it will guide the direction you want it to go. Are you using a newer Challenger heater box too? I wish more mopar builds were like this one!!
    14. #74
      Jan 2012
      Newton, KS
      Thanks! I appreciate the encouragement. The AC/Heat will be done with Vintage Air. It's already been mocked up. As far as the barracuda goes, it's on the back burner while I get this one going. I wanted a "simpler, faster" project but every project snowballs on me to some extent.
    15. #75
      Oct 2014
      DFW, Texas
      Lookin good! The Hemi + 6spd is a fun combo.
      1972 Plymouth 'Cuda - Not LS-swapped, 5.7L Hemi [MS3 Gold Box], T56 Magnum 6-speed - 'Cuda Build Page
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
    16. #76
      Jan 2012
      Newton, KS
      Driver's inner tub is in:
    17. #77
      Jan 2012
      Newton, KS
      Suspension was hung. First pic is at full up travel
      And extended:
    18. #78
      Jan 2012
      Newton, KS
      The AMD rear window lower corner patches weren't even close to being right. They took a ton of work to make them look right. Right rear window corner patch progression:
      It took a ton of work to make the window edge parallel the rear window trim this well.
    19. #79
      Jan 2012
      Newton, KS
      Left corner
    20. #80
      Sep 2009
      Great work on the metal finishing!
