    Page 3 of 12 FirstFirst 1 2 3 4 5 6 7 8 ... LastLast
    Results 41 to 60 of 232
    1. #41
      May 2011
      Brisbane, Australia
      Country Flag: Australia
      Very nice work and very nice parts. Coming along now.
      1966 Plymouth Fury III
    2. #42
      May 2008
      Austin, Tx.
      Man, great project and great work! You are SO lucky to have a friend like Matt! I am so jealous!
      Keep up the great job!
      Ray
    3. #43
      Jan 2012
      Newton, KS
      Quote Originally Posted by 454bug View Post
      Believe me: I know how fortunate I am to have such a skilled AND trustworthy craftsman doing all the fabrication!
      Here a few pictures of the K frame to better illustrate the cuts. The first picture is looking at the IRS frame from behind. The cut is a 1" slice that was taken from the right side, just outside of the right differential mounting bolt. A 1" slice was also taken out of the forward bar of the IRS frame (not pictured)
      The next two pictures are also taken from the back side of the IRS frame. The first picture is the passenger side where a 1.0" vertical cut was made to both bars of the IRS frame.
      This picture shows the "Z" shaped cut on the driver's side-just outside of the left differential mounting bolt. On the driver's side a straight 1" slice was not possible duet to the contours of the IRS frame and the left side differential bolt bushing.
      This is not the differential Ill be using. I plan to use a limited slip 3.91 Getrag differential
    4. #44
      Jan 2012
      Newton, KS
      We mated a 6.1 block to a TR6060 shell and dropped it in place
      This was the first time I got to sit in the car and make car noises.
    5. #45
      Jan 2012
      Newton, KS
      Transmission crossmember from below:
      Transmission crossmember from the top..
    6. #46
      Jan 2012
      Newton, KS
      Master cylinder and pedals were sourced from the Challenger SRT8 I parted out.
    7. #47
      Jan 2012
      Newton, KS
      I tried to sell these Challenger SRT seats for 6 months with no luck so I guess I'll use them in the Roadrunner. Usually I sell stuff and 2 months later I wish I hadn't so this was a nice change!
      The roadrunner has never had front seats in it for the last 20+ years so It was fun to sit in the car for the first time
    8. #48
      Jan 2012
      Newton, KS
      The pedals from the 2009 Challenger are mounted with 6 bolts. We tried to mount it with just 4 bolts, but the pedal bracket flexed too much so a plate with two more mounting points was added:
      View from the side. it will still be boxed in
      Pedals were hung but the and placed the pedals over the steering column hole. The pedals were heated and straightened. Then they were cut and the foot pads were removed/reoriented
      Before:
      After
    9. #49
      Jan 2012
      Newton, KS
      In order to keep the seats low and provide clearance for the electric motors, a custom pan was made under both front seats.
      View from below:
    10. #50
      Jan 2012
      Newton, KS
      I ordered a shifter with a 1.0" lateral offset (toward the driver) and 4.25" aft offset. Disregard the 4 speed pattern on the handle!
    11. #51
      Dec 2011
      Awesome craftsmanship and cool project, best of luck moving forward.
      Bossed
    12. #52
      Sep 2016
      great welds!!
    13. #53
      Jan 2012
      Newton, KS
      Here's the first part of the tunnel:
      The Holley Dominator ECU mounts to the top of the tunnel near the firewall. You can see it in the next 2 pictures:
    14. #54
      Dec 2010
      Apex, NC
      Beautiful work!
    15. #55
      Aug 2011
      Langdon, Alberta, CAN
      I am envious of your build and really like what you did for your subframe connectors! I will be looking at your build for future inspiration on mine, for now though I am just keeping it simple and getting the car on the road.
      [SIGPIC][/SIGPIC]
      1968 Plymouth Satellite build https://www.pro-touring.com/threads/...ICAN-CHALLENGE
      One year and only $7000
    16. #56
      Feb 2013
      Nice fab work! This will be a cool build!
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    17. #57
      Apr 2012
      Richmond Illinois
      Jan 2012
      Newton, KS
      Since the Photobucket extortion, I've been dreading the thread rebuild but I finally bit the bullet and installed all the pictures using imgur.com. If anyone else is still looking for options, you should consider imgur. I grown to like the site in the last week. Anyways...
      This is the second section of the tunnel has been roughed in and the new column has been installed. This picture also shown the shifter installed.
    19. #59
      Jan 2012
      Newton, KS
      The rear wheels are at ride height in this picture:
    20. #60
      Jan 2012
      Newton, KS
      The IRS is getting welded in so the frame rails were cut:
      This is the plate that will be welded in to cap the frame rail.
