Results 61 to 72 of 72
  1. #61
    Apr 2014
    Check out the link below. I stumbled on it a couple weeks ago but I am not sure how old it is. Fatman Fab is making shorter control arms for the crown vic front end. This is just a press release but should be useful for easing at least the front wheel sizing issues you are facing.
    http://www.fatmanfab.com/press-relea...r-control-arms
  2. #62
    Oct 2016
    New Brunswick
    Ok took the summer off of this project to finish some other things, but back to it now.
    Picked up a t45 transmission from a 2000 mustang because the decision to run an auto was killing me inside.
    Plan on going through it strengthening some things and upgrading the syncros so it will shift at the higher rpm the coyote will run.
    Also picked up the wheels I'll be running:
    Picked them up for a good deal locally. They are spec'd to fit a 2015 mustang which is the perfect size and offset that I need. Specs are 20 x 9.5 front and 20 x 10.5 rear.
    Here's where I'm at today in the build:
  3. #63
    The Druid City
    Will a T45 hold up? Maybe run a T3650?
    1970 GTO Version 2.0
    Instagram @projectgattago
  4. #64
    Oct 2016
    New Brunswick
    Probably not long term no. Some guys have used them with success. Using it mostly because it was cheap and available. Eventually will be swapped out for a t56
  5. #65
    Oct 2016
    New Brunswick
    Had a little bit of time in the garage tonight so I threw the rear end back under the car to check and make sure the rims would fit. Seem like it's going to work out just fine which is a relief!
  6. #66
    Oct 2014
    Wow, what a project. You've made some incredible headway considering what you started with! I dig the creative solutions, nice work!
    1988 Mazda RX7 - Forged LS/T56, 76mm turbo, ProEFI, Ford 8.8 - Sold
    1965 Mustang Coupe - TT Coyote, TR6060, big brakes, suspension. Basically a large car shaped hole in the ground I throw money into.
    2013 Focus ST - Daily Driver - FRPP Tune
  7. #67
    Jul 2014
    Las Vegas , Nevada
    That car is so right . They make beefed up crown vic racing arms for the back now. Great job , since my car was stollin , I need another monster .
    800 Amp Time Attack Thunderbird
  8. #68
    Jun 2017
    Wow, i just stubbled across this. Very nice. Torinos are my favorite cars. And i love the crown vic frame. Hats off to you. Keep up the good work.
  9. #69
    Oct 2016
    New Brunswick
    Started the bodywork on this car last weekend. Had some rocker panels bent up and started roughing in the drivers side quarter panel. I want all the gaps and everything set while the body is still on the frame before I pull everything back apart to be cleaned and painted. Still doesnt look like much but progress is definitely being made.
  10. #70
    Oct 2016
    New Brunswick
    Name:  Screenshot_20191110-201016_Amazon Shopping.jpg
    Welded the rocker panels in and I'm pretty happy with the fitment. Next job is to weld in the quarter panel. It needs to be butt welded because they dont make full quarter panels for this car. What's everyone's opinion on butt weld clamps like pictured? Is there a better way to do it?
  11. #71
    Sep 2009
    I was wondering what happened to this car. Glad you are still making progress!
    1968 Camaro LS6, T56, Z51 brakes, 12 bolt
    1976 T/A LS1, 6 Speed, C5 front brakes, and etc. SOLD
  12. #72
    Oct 2018
    Phoenix, AZ
    Quote Originally Posted by Sj_mr2 View Post
    I use those, but I almost prefer magnets more since you can get a tighter fit and it seems to help the panel be flush with the outside better. Eastwood has a magnet kit for panel work. Either way seems to work fine though if you really take your time.
