    Page 7 of 8 FirstFirst ... 2 3 4 5 6 7 8 LastLast
    Results 121 to 140 of 141
    1. #121
      Sep 2011
      Central Valley, CA
      Great build!
      Following along
      _____________
      Todd
      1965 Chevelle SS
    2. #122
      Nov 2018
      Nice looking, but I'd suggest some sort of guard on those component plates that you have on the interior firewall. You won't want your passenger's feet kicking any wiring loose under there by mistake. I'd also suggest trying to remove and install those spark plug wires with the engine in place now, while you're in a position to redesign. Something that looks cool when the engine's on the stand will definitely not be cool when you're replacing them down the road if you can't get at the wires without pulling the engine. No idea if you're installing air conditioning or not, but the brake booster and steering column are definitely going to make getting at those driver side plug wires a challenge.
    3. #123
      Jan 2016
      Quote Originally Posted by Vimes View Post
      Thanks for the tips! The only components are above the tunnel in center so won’t be close to feet. The other plate will be for future heater which is in same position it would be normally; just offset from firewall an inch. The plug wires are able to be removed with the body on the frame. No AC or brake booster.
      - - - Updated - - -
      Quote Originally Posted by 1965_SS View Post
      Great build!
      Following along
      Thanks!
      Chris Johnson
      '66 Chevelle Malibu
    4. #124
      Jan 2016
      Spring 2021 Progress Update on 66 Chevelle
      Lots more to share as the assembly continues this spring! Have put quite a bit more time into it and it is really starting to come together now which is fun to see.
      Finished designing circuits to run through relays and received all of the components to build the RTMR boxes. Found a good place to mount the boxes that is out of sight but still can get the covers off to swap relays and circuit breakers if needed. Mocked it up out of cardboard first and then transferred to steel.
      Lokar shifter boot and door weatherproofing
      Mockup and fabricating throttle cable adjuster bracket extension to correct the cable alignment to the adjuster with Holley Sniper throttle lever extension (installed for better throttle control). Using Lokar throttle cable and aluminum cable bracket kit. Had to get a new air cleaner base that was less of a drop to clear the throttle extension and shorten my throttle body spacer using a Mr. Gasket rubber gasket/insulator/spacer to bring the air cleaner back down to clear hood
      Wegner adjustable PCV valve with clear hose to inspect for oil suction when setting. Will also be checking out the oil splash shield on underside of valve cover to make sure there isn't a place for oil to pool per recommendation by Wegner. This has a fixed orfice mode that some have said is probably the way to go for self-adjusting EFI so that the controlled vacuum leak is more predictable than having more flow come on at higher vacuum.
      New original style door panels from Distinctive Industries
      Chris Johnson
      '66 Chevelle Malibu
    5. #125
      Looking Good! Nice job on the bracket holding the panel. Your moving along nice.
    6. #126
      Jan 2016
      Thanks! More updates getting uploaded yet!
      Chris Johnson
      '66 Chevelle Malibu
    7. #127
      Jan 2016
      More Spring 2021 Updates to 66 Chevelle
      Re-upholstered the armrests
      Making the fuse-to-relay jumper wires for the RTMR boxes. Metripack 280 terminals. Crimped and soldered.
      Chris Johnson
      '66 Chevelle Malibu
    8. #128
      Jan 2016
      More Spring 2021 Updates on 66 Chevelle
      Soldering RTMR jumper wires
      Ordered up some parts for the rear end from Strange Engineering to upgrade the pinion yoke to a 1350 U joint size including a much heavier-duty LPW cover paired with a LubeLocker gasket for hopefully no more seeping and easy service. Nice piece! The chromoly yoke and caps from Strange are really nice too and will get some photos of those as soon as the new driveshaft is done and gets mounted.
      To hold the pinion yoke while torquing the nut and to pull the yoke back off when setting the bearing drag, I got a really nice tool from Massive Speed Systems in Chicago. Job would have alot worse without this.
      Routed the Lokar emergency brake cables to the new Lokar handbrake that I replaced the foot parking brake with
      Refinished steering column support bracket and added stainless hardware there too like I'm doing for about everything
      Dash mounted
      Routing the dash harness from the AAW Classic Update kit
      Dad and I routing supply and return fuel lines from the new in-tank Walbro fuel pump in the new Tanks Inc. EFI-ready fuel tank to the Sniper EFI throttle body using Earl's Vapor Guard 3/8" hose and a Vapor Guard 10 micron inline filter.
      Found a good, high spot for the rollover vent valve too and fabbed a little aluminum bracket for it.
      Steering column back in and all THREE pedals hooked up to the brake and clutch masters!
      Chris Johnson
      '66 Chevelle Malibu
    9. #129
      You guys are doing a nice job all of this. That's quite a soldering station you have there. Those diff covers are nice I had one for the Camaro before I went to the 9". Keep plugging away.
    10. #130
      Chris,
      Great job on everything. When you're ready to get that Sniper system tuned up, please keep me in mind.
      Instagram @projectgattago
      Dr. EFI
    11. #131
      Jan 2016
      LONOVE Soldering Iron Station Kit... https://www.amazon.com/dp/B08J7VLJ49?ref=ppx_pop_mob_ap_share://www.amazon.com/dp/B08J7VLJ49?ref=ppx_pop_mob_ap_share
      Yeah the soldering station was from Amazon and working really nicely. Linked:
      - - - Updated - - -
      Chris,
      Will do! Thanks for the electrical tips!
      Chris Johnson
      '66 Chevelle Malibu
    12. #132
      How are you doing on the Chevelle? Any updates?
    13. #133
      Sep 2017
      Quote Originally Posted by WildCherry66 View Post
      Dash mounted
      Chris
      Great job on this build especially with fab work and electrical This is the first time I've seen it. It's awesome keep it up
      Jason
      Jason's 67 Pro touring Camaro build
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    14. #134
      Jan 2016
      Been still plugging away on the wiring as time allows. Only some engine bay wiring remains now and it will be ready to fire up!
      Chris Johnson
      '66 Chevelle Malibu
    15. #135
      Jan 2016
      Quote Originally Posted by TANKMASTERJ View Post
      Chris
      Jason
      Thank you! It’s been a great project for learning new things and taking my time to do it with as good of quality as I can!
      Chris Johnson
      '66 Chevelle Malibu
    16. #136
      Jan 2016
      It's alive!
      Been awhile since I've had time to post updates, but it's alive!! Got all of the wiring wrapped up in October 2021 and dad and I button up some pre-fire up tasks Saturday and Sunday 10/23-10/24 and were able to turn the key Sunday night and it fired up and ran on the first try with no issues! This was pretty satisfying being a freshly rebuilt engine, Sniper EFI and Hyperspark ignition added, 100% new wiring with a lot of customization and integration of many different systems, and being the 1st time ever attempting a rebuild like this. With some additional things to finish up before it could be driven after that, I was able to get it out for it's first drive on Halloween 2021. Since then, been working on learning about the Holley software and honing in on the tune and working on some other small things to get it ready for more miles this summer. Feels good to be able to turn the key and drive it around now! Been a long process but a rewarding one. The wiring was the most intimidating not knowing much about it, but once I learned how to do it and had the right tools and components, it was actually fun and a good feeling having made every single termination myself.
      Chris Johnson
      '66 Chevelle Malibu
    17. #137
      Jan 2016
      2021 pics - Aluminum driveshaft, vent door restoration, Vintage Air Heater Install
      4" aluminum driveshaft with 1350 joints made by Midwest Welding and Drive in Fargo and Strange 12 bolt yoke and billet caps
      Restored the kick panel fresh air vent door assemblies with new seals and cables
      Vintage Air Heater-only with the upgraded controls. Decided it was going to be easier to install that before finishing the wiring and filling the coolant so pulled the trigger on it. Mounted it on the aluminum standoff plate behind the glovebox so completely hidden with nothing visible from engine bay side.
      Custom bracket to mount the controls under the dash where they aren't noticeable since I converted the space from the original controls into a cubby for phones/wallet
      Interior wiring done! Stock appearance with many subtle changes. Came out nice and clean.
      Chris Johnson
      '66 Chevelle Malibu
    18. #138
      Jan 2016
      2021 Pics - 66 Chevelle build updates
      Finished RTMR boxes
      Name:  <span style='whitespace: nowrap'><a href='https://www.optimabatteries.com/en-us/redtop-starting-battery?utm_source=ProTouring&utm_medium=Display&utm_campaign=FY%2719_Brand_Media&utm_content=RedTop' onclick=battery-cable.jpg Views: 295 Size: 130.1 KB" style="float: CONFIG" />
      Making main power and ground cables
      Engine bay
      Connected power for first time - no fires and everything works!
      First start up on 10/24/21. Fired up on first try and no issues!
      Chris Johnson
      '66 Chevelle Malibu
    19. #139
      Congratulations on the first start up! Nice clean job on the engine compartment, glad you got to use it a little. Did you get a video of the startup?
    20. #140
      Nov 2018
      Looks great. I wish they still put the kick panel vents in. Had a 79 GMC with them that did not have air conditioning, and with those panels and the wing windows, air conditioning was rarely missed.
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
    Tags for this Thread
