    Results 1 to 9 of 9
      Oct 2006
      Can a Sub Woofer be used as a Woofer? 8" Audio Pipe, confused...
      1234
      Tallahassee
      Probably would be fine in a proper enclosure with a proper amp. An old scool Sony XEC505 with bass gain would do wonders for it.
      I assume you are going to use a crossover and not play it full range?
      That being said....it is just an 8" speaker.
      Oct 2006
      Quote Originally Posted by pitts64 View Post
      Yes, I'm using an Audio Pipe crossover. The woofer will be mounted in the wooden cabinet... I also have a pair of tweeters were the old 4 x 10 speaker was.. I removed all the hvac from the car, so I have a lot of room under the dash..
      Thank you!!
      Attachment 135511
      Attachment 135512
      Attachment 135513
      Attachment 135514
      Dude...You're fired...
      Don't use those wire twisty things in a car.
      Instagram @projectgattago
      Dr. EFI
      Jonesboro, Arkansas
      What I'm sayin'.......
      Carl Wilson
      May 2010
      kitchener,Ontario,Canada
      Yep I agree with the other fellas say those are a bumpy road away from a dash fire or blown fuses ....no regardless of the amps or speakers .....get a real head unit ...if the amp is getting "dirty signal" it won't matter what amp you have . Having said that a cross over is highly recommended. Once you have those things figured out then worry about speakers . Any speaker will play basically any sound (loosely meant for you fancy guy ) using a cross over to funnel a certain frequency range that matches what said speaker performs best at will obviously provide the best sound
      Ryan Austin
      On twitter @raustinss
      On Instagram austinss70
      Oct 2006
      Oct 2006
      Can you elaborate on all the drivers and what they actually do?
      Dr. EFI
