    Results 1 to 17 of 17
      Oct 2014
      DFW, Texas
      Custom A/C hoses - who's kit?
      I have a Vintage Air Evap and condensor with #8 and #10 fittings on the Compressor. I would like to run the high side line from the drier to the evaporator through the fenderwell and back through the firewall. The low side line I would like to run behind the engine back over to the compressor [driver's side].
      Who can I buy fittings and hose from? It seems like I need a universal kit of sorts with a long rubber hose and select the fittings.
      I recommend Eaton's EZ-Clip hose and fittings. You can assemble it yourself, the hose OD is minimal, and the bend radius is great. Vintage Air sells it.
      http://www.eaton.com/Eaton/ProductsS...ngs/PCT_259178
      John Parsons
      Metamora, Illinois
      X2. I used them when I made mine and would highly recommend. A little pricey but worth it
      Feb 2014
      Georgia
      I used the EZ-Clip hose and ends on my Roadrunner. I got everything I needed at Hose Warehouse Hosewarehouse.com including the crimping tool for a lot cheaper. I can get you part numbers of the fittings I used if you need them as the online EZ-Clip catalog can be confusing.
      Steve - 1970 Roadrunner
      Jul 2016
      Reduced barrier hose is easier to bend as well. Highly recommend.
      Jan 2013
      Abbotsford, B.C.
      Eaton ez clip hose from hosewarehouse.com I found the crimper on eBay for $10 shipped
      Oct 2014
      DFW, Texas
      Thanks all!
      Quote Originally Posted by LemonTwisted View Post
      I think that would get me started if you can find those numbers?
      Aug 2009
      Love the EZ clip...No other way will do
      Sep 2013
      Houston, TX
      I'd like to know the parts numbers too, when you get a chance to post them. Thanks.
      Rodney Meyers
      72 Olds 442 Rest-mod clone
      Chit-ca-go
      Prices on that site are better than at VA and I'll agree on it being confusing.
      1971 Firebird
      2017 Slipstream SS
      Feb 2014
      Georgia
      Quote Originally Posted by GoodysGotaCuda View Post
      Thanks all!
      Sorry for the delay, been busy during the holidays. I'll work up a listing for the fittings that I used and post up this evening.
      Chit-ca-go
      Hopefully this is correct...I went through the kit and tried to match up the parts at hosewarehouse.com:
      If you go to page 4 here: http://www.vintageair.com/Instructions2013/907002.pdf
      This where the hosewarehouse.com part numbers match up in order if I did this correctly.
      1. GH134-06 (10')
      2. GH134-08 (6' )
      3. GH134-10 (5' )
      4. 22546-11 (5)
      5. 22546-13 (2)
      6. 22546-15 (2)
      7. FJ3013-03-0808S
      8. FJ3012-02-1010S
      9. FJ5984-0606S
      10. FJ3055-01-0606S (2)
      11. FJ5985-0606S (2)
      12. FJ3055-030808S
      13. FJ5984-1010S
      14. 1F40105-06C (5 )
      15. 1F40104-06C (10)
      16. 1F40105-08C (2 )
      17. 1F40104-08C (4 )
      18. 1F40105-10C (2 )
      19. 1F40104-10C (4 )
      20. Grommet, Large (these should be the same as the ones included with the VA kit already unless I'm mistaken)
      21. Refrigerant oil for hose assembly (will any do or something specific?)
      The pliers and cutters are $52.81 & $35.19 as of this posting. They may be available elsewhere cheaper, but I haven't looked yet.
      I haven't added the other parts up to see what the exact difference would be.
      If anyone sees any mistakes, please let me know.
      1971 Firebird
      2017 Slipstream SS
      Feb 2014
      Georgia
      Quote Originally Posted by cpd004 View Post
      1. GH134-06 (10')
      2. GH134-08 (6' )
      3. GH134-10 (5' )
      4. 22546-11 (5) - #6 o-ring
      5. 22546-13 (2) - #8 o-ring
      6. 22546-15 (2) - #10 o-ring
      7. FJ3013-03-0808S
      8. FJ3012-02-1010S
      9. FJ5984-0606S - #6 straight to #6 hose
      10. FJ3055-01-0606S (2) - #6 45* to #6 hose
      11. FJ5985-0606S (2) - #6 90* to #6 hose
      12. FJ3055-030808S - #8 45* to #8 hose
      13. FJ5984-1010S - #10 straight to #10 hose
      14. 1F40105-06C (5 ) - #6 cage
      15. 1F40104-06C (10) - #6 clips
      16. 1F40105-08C (2 ) - #8 cage
      17. 1F40104-08C (4 ) - #8 clips
      18. 1F40105-10C (2 ) - #10 cage
      19. 1F40104-10C (4 ) - #10 clips
      The descriptions highlighted in Blue are the exact same fittings that I used. I'm assuming the other 2 fittings are the high and low side port fittings, I used FJ3054-1010S - #10 straight to #10 hose with low side port and an EJ3410-0808S - #8 45* to #8 hose with high side port to work with the my low mounted compressor on a big block Mopar. I ordered a few extra cages, clips and o-rings just in case.
      Chit-ca-go
      So far, #9 and #13 will not work with the evaporator. They are staright -6 and -10 as listed and should be 90's. I'm not sure if all evaporator units are the same, but for my 70-81 F-body kit, these should be :
      9. FJ5985-0606S (90 Deg -6)
      13. FJ5985-1010S (90 Deg -10)
      The rest of the kit looks like it'll work, but no way to tell for a while as I'm not quite there yet.
      1971 Firebird
      2017 Slipstream SS
      Jul 2011
      Is ez clip hose and reduce barrier hose the same ?
      Mountain Springs, Texas
      Quote Originally Posted by Bmf5150 View Post
      No.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Oct 2015
      Western Mass
      Does Reduced Barrier Hose go by some sort of technical name at Hose Warehouse?
      '69 LeMans Blue Coupe, White Interior, Massaged .030" over 454, Super T10 4-Speed,
      Holley 4150, Pertronix Ignition, CompCams Xtreme Energy XS274S, 781 Oval Port Heads
