Results 1 to 9 of 9
10-28-2016 #1Registered User
- Jul 2011
- 134
BEAST MODE 665 HP LS7 Powered 1969 Camaro G-Machine For Sale $130,000.00
Painted PPG Ferrari Grigio Medio
Anvil Carbon Fiber Front Fenders, Front Valance, Header Panel, Cowl and Hood. Fiberglass Hood Vents.
Aerocatch Hood Latches and Trunk Lid latches
Stock Style Door Mirrors, Door Locks , Front and Rear Window Trim, Taillight Housings, Front Grille, Z/28 Badges
Stock Style Front and Rear Spoiler both in black, stock style windshield wipers
Ring Brothers Black Billet Door Handles
Digitails LED Taillights, Rivera Primo LED Headlights with integrated amber turn signals
Schwartz Performance G-Machine Chassis with Baer 6P 6 piston calipers and 14” Rotors front and rear.
Moser Full Floating 9” Rear End. Aluminum Third Member w/Wavetrac Differential. 4.56Gear
ridetech Triple Adjustable Shocks Front and Rear. Hypercoil Springs.
Gun Drilled Front Sway Bar. AGR Performance Rack
Thomson Automotive/Lingenfelter All aluminum LS7 427. 665 Horsepower 571 Lb/ft on 93 Octane Gasoline. Callies Dragon Slayer Crankshaft, Oliver Rods, Diamond Pistons, Trend Pushrods, Custom ground Comp Cam. Comes with build book and Dyno Sheet
Billet Specialties Tru Trac LS7 Sepentine Front Drive System
Peterson Fluid Systems LS7 Aluminum Dry Sump Tank and Breather
Katech Valve Covers and Coil Pack Relocation Kit
AeromotiveLS7 Fuel Rails, Aeromotive Fuel Regulator
Tremec T-56 Magnum Close Ratio Transmission
QuickTime Bellhousing, Longacre Shifter Lever, Hurst Shifter Ball
Dynotech Engineering Custom 3.5” Aluminum Driveshaft
MSD Dynaforce Starter
Ram Force 9.5 Dual Disc Clutch with Billet Throw Out Bearing
Forgeline GA3R Wheels Triple Gloss Black, Hidden Hardware Option
18X11 Front Wheel with a Falken Azenis RT615k 315/30ZR18 Tire
18X12 Rear Wheel with a Falken Azenis RT615k 315/30ZR18 Tire (will easily fit a 345 rear tire if desired)
Willwood Racing Master Cylinders and Pedals
Ididit Steering Column
Spek NASCAR Gauges
Anvil Auto Fiberglass Dash Insert
Kirkey Road Racing Seats
Schroth NASCAR 6 point Harnesses
MOMO NASCAR steering wheel from Max Papis Inc.
Joes Racing Carbon X Shifter boot
Joes Racing Rear View Mirror
Fesler Billet Black Anodized Trunk hinges
Braille 21 pound AGM battery
B&B Classics Braille Battery Mount in black powder coat
II MUCH Fabrication Fuel Vent
Joes Racing Rear Differential Vent
18 Gallon Aluminum Fuel Cell
vaporworx fuel pump Controller
Gen5 Camaro ZL1 Fuel Pump
Borla XR1 Mufflers, Speedwerx Custom Headers, 3” Exhaust
RAINGEAR hidden wiper kit
VintageAir Defrost Heater
Stockstyle headliner, Door Panels and Dash
Custom Carpet and Rear seat area. No back seat
Ring Brothers Billet Air Frame Hood Hinges (Black Anodized) Billet Door Strikers, Billet Door Jam Vents
Auto Rad Radiator with a custom Aluminum Core Support, Dual Electric Fans andShroud
-20 Earls Fittings on upper and lower radiator Hoses
2 H3R Performance 2.5 LB Black Halguard Fire Extinguishers with Joes PerformanceQuick Release Mounts
Integrated Full Roll Cage. Custom underhood down bars, dry sump tank mounting mid plate, Custom Floor, Custom notched and smoothed Firewall with engine set back approximately 10 inches from stock location, Custom Trunk Floor
Endless hours of fabrication resulting in a unique one of a kind 1969 Camaro for cruising, racing or showing
100% New components on a freshly completed build.
The build thread with multiple details and photos can be viewed here: https://www.pro-touring.com/threads/1...Mode-69-Camaro
If you were to have this car re-created by a professional shop it would likely cost you double what I am asking for it. There are many great components on this car and it is well worth the asking price. The car drives incredibly well, draws a lot of attention and performs well at speed if you intend on racing it and it looks incredibly cool while doing all of the above. I am selling the car because of personal/financial reasons, otherwise I would have never considered parting with it. The car attended two shows this summer and it was fortunate enough to receive an editors choice award from Power and Performance News while attending the Street Machine Summer Nationals in Saint Paul, Minnesota.
Please PM me or contact me at 651-592-FIVE ONE TWO SEVEN if you are serious about buying this one of a kind Camaro.
Thank you for your interest
