    Page 21 of 30 FirstFirst ... 11 16 17 18 19 20 21 22 23 24 25 26 ... LastLast
    Results 401 to 420 of 583
    1. #401
      Oct 2016
      Adaptive Vr conditioner welded and installed so my ECU is capable of reading 4 vr sensors.
      Awaiting for a clutch switch to trigger launch control and I ll wire the red on/off toggle switch to unable/disable it.
      I keep the blue switch for traction control.
    2. #402
      Sep 2017
      Hey Bernardo from France! Jason aka tankmasterj from Arkansas usa!
      Lots of great engineering going on in your rig. Keep it up I love checking in on your build.
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    3. #403
      Oct 2016
      All wiring finished, finally installed 3 on/off switches instead of 2.
      One for launch control with a clutch switch , one for traction control and one for pit lane limiter ( a sort of launch control during driving situation, rpm or vss is set at a fixed point or held with the switch, you build boost at your desired speed and you kill the supercars )
      Interesting on 1/2 miles or 1000m when you begin at 35mph or 50 to 75 mph, 63 to 125 mph ...etc
      I've not looked at speed based launch control for the moment but it looks interesting too.
      I've bought courses on HP Academy to have more knowledge on how to tune an engine correctly and be ready to go to dyno.
    4. #404
      Oct 2016
      Finally driven a bit today under snow but it's allways a pleasure !
    5. #405
      Oct 2016
    6. #406
      May 2012
      Kansas City, Missouri
      Cars always look better when there is a chick standing by them. Car looks awesome
    7. #407
      Oct 2016
      Thx !
    8. #408
      Oct 2016
    9. #409
      May 2012
      Very nice pics!!!
    10. #410
      Oct 2016
      Thx !
    11. #411
      Yeah. Happens ALL the time with a white Camaro SS.
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
    12. #412
      Oct 2016
      A friend needed cars for a long time to shoot models so I say yes why not ! We ll make videos later without models and for the moment I can't go to dyno because of covid...and I still don't know how to wire those ABS sensors, awaiting for a data sheet from SKF.
      Last week I ve killed 3 Porsche Carrera 4s lol they were not happy
    13. #413
      Oct 2016
      Talking about brake Performance, I bought polymatrix B pads couple of months ago, they are incredible ! Day and night versus the base pads avaible on all wilwood kits. Just a bit noisy when hot but really efficient, it stops the car.
      My cooling issue is solved with those holes on the front spoiler and the new champion 4 row radiator. Last week I made about 15 runs at full boost, temp never goes above 185°F, almost cold under cruise at 170°F . I ve ordered a 195°F for winter and I keep the 180°F thermostat for summer.
      And I will increase the boost from 18 to 23psi to go above 1000hp and see how much boost I need to add at the dyno to reach the 1200.
    14. #414
      Oct 2016
      Several years ago when I ve installed the Speedtech torque arm with the ridetech TQ coil over shocks I put the adjustable bottles under the car and it's not easy to adjust because I needed to lift the car...etc So today I ve just relocated them inside the trunk so I can set my shocks easily for street, road racing or circuit for example. I just need to plug the hole now.
    15. #415
      Jonesboro, Arkansas
      Car.....? what car? No, really very nice Camaro..... and model.
      Carl Wilson
    16. #416
      Oct 2016
      Thx !
    17. #417
      Oct 2016
      It's been a long time I don't talk about perfs, here are 3 logs with the data necessary to know if everything is going well or not for my engine, the fuel supply (sensor 3 being the fuel pressure in psi) afr. ... etc, we can look at a lot of other data of course. The afr 1 and 2 compared to target afr allow me to correct the VE table manually to be right on the afr target. The fuel pressure and the fuel flow let me know if my fuel pumps are performing sufficiently compared to the manufacturer's curves. The duty cycle represents the injector's % of use, still a margin with the id2000 since they can be used up to 95%. The water temperature and the manifold air temperature ... etc. I have of course other essential data displayed on the dashboard such as the oil pressure for example.
      With these data I can estimate the instantaneous engine power thanks to the rbracing boost and airflow calculator on the internet that I had already used several times and which was very similar to the power output on the dyno with my previous engine.
    18. #418
      Oct 2016
      No loss of fuel pressure and afr are good with 22psi of boost
      Just ordered 11psi middle spring for my 2 hypergate 45 wastegates, with a total of 26psi of boost I think the 1200hp goal at 7000rpm will be reached and probably the limit of the 2 walbro 535 at 95psi of fuel pressure too.
    19. #419
      Oct 2016
      Some news here I ve tested a bit more boost and I did not see a big difference so if I don't have any boost leak I wonder if I ve maybe reached the limit of my turbos probably even at 22 psi of boost. The bank's kit is made for 1100hp so I think I need some bigger to reach 1200-1300..
      And I ve finally logged 2 speeds, one from my transmission and one from the ABS sensor ! Now I need to set correctly the pulse per mile and get a correct speed compared to gps
      So these ABS sensors are active sensors that need a 12v feed, a signal return.
      Following links some videos
      https://youtu.be/Bg_p_xgUIkA
      https://youtu.be/M5GSrPlCFV8
      https://youtube.com/shorts/6s-h5Nkv4Ic?feature=share
    20. #420
      Sep 2017
      Quote Originally Posted by berdunord View Post
      Dang Bernardo that car is kick ass. My white 67 just came off the rotisserie. About to but front and rear suspension under and start the assembly as soon as all my sheet metal parts are painted.
      Keep it up.
      tankmasterj
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
