    Page 11 of 30 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 21 ... LastLast
    Results 201 to 220 of 583
    1. #201
      Oct 2016
      Thanks a lot !
      Today I ve finished all wiring with the dakota digital hdx instrument, awesome paired with the ms3-pro evo I can see all I need from the engine on the dashboard and the all in one app from Bowler let me set the speed as I want even if I change the rim size, no need to change the speed sensors, just calibrate it with the bluetooth app
    2. #202
      Oct 2016
      Some news here I ve finished all wiring so now I will be able to begin the interior restauration.
      To evacuate heat I ve installed 2 hood scoops on the fiberglass hood, hope it will be enought to lower t° of the engine bay.
      And installed a radio gps, it s not really beautifull for the moment but with the new center console I will build everything will be hide and look better.
      And bought a pair of modern universal headlight bracket cause one of my original one is dead.
    3. #203
      Oct 2016
      I had some ignition issues, found it lol
      About fuel consuption with new ngk br6eix iridium spark plugs good up to 15 psi of boost, registered on a flat road at 50mph and about 30s, an average of 33 mpg !
    4. #204
      Oct 2016
      4.0 installation, 800 watt rear, 300 watt front, a total of 1100 watt for a 1100hp street car !
    5. #205
      Oct 2016
      Finally bought 2 250 watt car speakers with the same sound technology as rear from Pioneer, making 1300 watt sound is amazing !
      I ve replaced the original headlight housing with universal 7inches from anvil auto. Now this is strong and reliable.
      I m finishing the interior with dynamat, dynaliner and a true carpet from Renault.
      About the engine I will go to the dyno soon and fully tuned the AFR , VE and spark table.
      Transmission and différential break-in is finished, after changing the oil I will finally be able to tune the 4000-7500 rpm zone
    6. #206
      Oct 2016
      Today finally finished dynamat xtrême everywhere and dynaliner 1/2. Next step covering with carpet and black vinyl.
    7. #207
      Oct 2016
      Finally I ve re-used all plactic sail panel ...etc all covered with acoustic carpet. The floor will be covered with Renault carpet
      I wonder if I should buy TMI sport XR rear seats upholstery to match with the door panel.
    8. #208
      Oct 2016
    9. #209
      Oct 2016
    10. #210
      Oct 2016
      Replacing oil and coolant today, here is what I use.
      About the injectors I had an issue with the id2000 because I did not know that injector dynamics gives the good small pulse widht and dead time values on their website so it did not work well and I think the mpg values record on the megalogviewer were wrong.
    11. #211
      Oct 2016
      This will be way better with the TMI rear seats upholstery !
      Changed my fpr by an aeromotive xtrem flow rated at 2.5 to 5 gpm and the throttle cable with a lokar cut to fit.
    12. #212
      Oct 2016
      A small video it s been a long time I would like to do that coin test !
      https://m.youtube.com/watch?feature=...&v=gZhveILuXFU
    13. #213
      Oct 2016
      Wow this is heavy ! 4100 lbs about the same weight as a Bugatti veyron, I need more boost lol
    14. #214
      Sep 2009
      Sweet car man. I would have to guess that the 33mpg is incorrect haha.
    15. #215
      Oct 2016
      Thanks ! Yes this is completly wrong cause I had wrong pulsewidht and dead time numbers. With the good numbers now I have an average of 15 mpg on highway with E85
    16. #216
      Oct 2016
      Next modification and probably the last, I get that power rack and pinion coming from a bmw e36 328i, that is used on drift racing with 285 tires so strong enought for my car and a modern steering !
    17. #217
      Oct 2016
      ordered today an universal defroster kit for rear window, this is really dangerous driving under rain and see nothing. It's been a long time I'm looking for this but nothing found in EU as usual....
      and a modern power window switch cause the original one is not really reliable.
      next week I'll send my id2000 to injector dynamics for re-calibration to get them like new
      https://www.frostfighter.com/clear-v...list-12v-1.htm
    18. #218
      Oct 2016
      awaiting for my injectors in repair at injector dynamycs, I have time to work on intercooler pipes polishing, still not what I want but it's a good begin
      the new power window switch works really better than the original one, windows goes up and down faster than before, $16 on amazon really worth the price !
    19. #219
      Jul 2011
      Stafford Va
      keep it up I am getting some good ideas for m 72 Camaro
    20. #220
      Oct 2016
      You are welcome !
