    Page 4 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
    Results 61 to 80 of 168
    Thread: 1972 C10 Build
    1. #61
      Chicago
      Holy crap You have my attention !
      What an awesome truck
      marty-mj
    2. #62
      Jan 2016
      Arizona
      Thank you! I will update with more pictures as more gets done
    3. #63
      Jan 2016
      Arizona
      1972 C10 Build
Size:  177.8 KBName:  IMG_7315.JPG
Size:  208.4 KBName:  IMG_7316.JPG
      Update
    4. #64
      Jan 2016
      Arizona
Size:  240.5 KBName:  IMG_7369.JPG
      Hot side mocked up
    5. #65
      Nov 2018
      Nice looking so far, but I can't see how the compressed air piping will go. Looking forward to seeing this finished.
    6. #66
      Sep 2016
      LA - Lower Alabama
      In the for the updates! This is a cool setup.
      Dude are you made of leprechauns? Cause that was awesome!
    7. #67
      Jan 2016
      Arizona
Size:  548.4 KBName:  IMG_7467.jpg
Size:  158.1 KBName:  IMG_7466.jpg
      Stopped by and got a few more pics. Upgrading the fuel system as well.
    8. #68
      Jan 2016
      Arizona
Size:  228.7 KBName:  IMG_7476.JPG
    9. #69
      Jan 2016
      Arizona
    10. #70
      Sep 2016
      LA - Lower Alabama
      There's that answer! Looking good!
    11. #71
      Jan 2016
      Arizona
      Quote Originally Posted by AU Doc View Post
      Thanks man
    12. #72
      Jan 2016
      Arizona
Size:  454.7 KBName:  IMG_7703.JPG
      Air to water plumbed except for ice tank, wired everything with weather pack connectors, gates installed, everything is welded. Getting there
    13. #73
      Nov 2018
      Nice looking, was wondering how you'd get that pressurized pipe to the front.
      I would screen that radiator right behind the tire with something fairly rigid, like welded mesh. Anything you hit (and stuff can't always be avoided) will be slung into it hard, and some of the stuff you might hit can break that.
    14. #74
      Jan 2016
      Arizona
      1972 C10 Build
      Thanks for the tip, will try to get it solved if it becomes an issue.
    15. #75
      Jan 2016
      Arizona
      1972 C10 Build
      Dual Holley 450’s installed with the aeromotive regulator, 850cc Bosch injectors, Holley rails, I believe -10 feed with -8 return. We did all PhenIx crimp fittings as well. Just waiting on the flex fuel sensor and the fuel system will be done.
    16. #76
      Jan 2016
      Arizona
Size:  245.1 KBName:  IMG_7800.JPG
      Intake tube almost done
    17. #77
      Aug 2002
      Waleska Ga.
      Cool project!
      just wondering what your plans for oil and return for the turbos ?
      I'm doing a single turbo in the smugglers box on a 1970 Elcamino,
      I would like to mount it low but was considering mounting it higher for oil return lines to motor.
      Thanks for sharing.
      David Sloan
    18. #78
      Jan 2016
      Arizona
      Quote Originally Posted by David Sloan View Post
      Cool project!
      Thanks for sharing.
      We are running the oil feed off the little block above the oil filter and the return will T off into a scavenge pump and will return to the valve cover. Thanks man
    19. #79
      Chicago
      Looks great I can’t wait to see more pictures
      marty-mj
    20. #80
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by Cshenker1121 View Post
      Thank you sir!
      I had thought about running a scavenge pump, I'm a little ways from worrying about it yet but may do that as well to keep the turbo lower.
      David Sloan
