    Page 6 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
    Results 101 to 120 of 123
    Thread: 1972 C10 Build
    1. #101
      Jan 2016
      Arizona
      Very cool build...I am not sure how I missed it before...
      Thank you!
    2. #102
      Jan 2016
      Arizona
      So after driving it for a few days, we noticed the turbine and compressor housings were seeping oil, enough to get into the charge tubes and the exhaust. So we are building a sump tank for the turbos to drain into, then from there it will go into the scavenge pump and up into the motor. We also think some of this has to do with there not being check valves on the feed lines. So Iím going to remedy both of those issues.
      I also pulled some of the turbo kit off to clean out the oil and while thatís being done I dropped off the turbine housings to get ceramic coated hoping it will help with the temperatures seeing they are next to wiring/ brakes lines etc.
      The turbos work awesome, Just need to perfect the oiling system for them is all. At least itís something simple
    3. #103
      I was going to say something about the need for little sumps for the oil drains...but....LOL
      1970 GTO Version 2.0
    4. #104
      Jan 2016
      Arizona
      Yeah the company we got the scavenge pump from assured us it has the power to pull the oil without the tank. And letting it run after itís shut off with a timed relay would work perfectly fine and oil wouldnít run back. Welp they were WRONG lol
    5. #105
      Quote Originally Posted by Cshenker1121 View Post
      Check out DigitalSolos Mustang build.
    6. #106
      Jan 2016
      Arizona
      1972 C10 Build
      I like how he did his, Iíd like to do something similar for the little tanks under mine but unfortunately I feel it would be difficult considering my turbo drain bolts is how my turbos mounted in place. That is a bad ass car.
    7. #107
      Jan 2016
      Arizona
Size:  374.6 KBName:  IMG_8726.JPG
Size:  573.7 KBName:  IMG_8735.JPG
      So after brainstorming with these guys we came up with the solution to control the oil problem
      We put a check valve in the oil return line after the scavenge pump, put in a sump tank, made new return lines , and also put check valves in the oil feed lines. So far no oil issues. Put some miles on it today and no smoke or oil seepage. And to help control the heat I got the exhaust housings ceramic coated. Name:  IMG_8646.JPG
    8. #108
      Jan 2016
      Arizona
    9. #109
      Jan 2016
      Arizona
      Now I am working on venting the crankcase. The single catch can I have with the little lines arenít going to work, it was good enough for the stock engine but not now. So I am now running two moroso catch cans with a -10 to each valve cover. Iím getting the fitting welded this week and will make the other line. Just trying to perfect it as I drive it more.Name:  IMG_9118.JPG
Size:  437.0 KBName:  5A63FA4A-7599-44EB-AE1C-5DC4A112CAD0.JPG
Size:  517.5 KBName:  IMG_9121.JPG
    10. #110
      Jan 2016
      Arizona
Size:  342.2 KBName:  IMG_9177.JPG
      Done!
      If both valve covers are vented can I remove the little pcv hose the goes from the valley cover to the intake and cap off both ports?
    11. #111
      Jan 2016
      Arizona
Size:  596.1 KB New 4Ē aluminum driveshaft, my old one had a bunch of run out and vibration. So hopefully this will help.
    12. #112
      Jan 2016
      Arizona
      1972 C10 Build
      Put V bands on the headers to stop the exhaust leaks, they were driving me nuts. Weighed the truck too.
      Big stereo with 2 12ís and an amp
      Twin turbo LS3
      T56
      AC
      Air to water with ice tank
      Longbed
      Hotchkis suspension
      Full interior
      ECE truck arms
      Full tank of gas
      3900lbs 55/45
Size:  454.2 KBName:  IMG_0742.JPG
Size:  434.0 KBName:  IMG_0743.JPG
Size:  548.8 KBName:  IMG_0734.JPG
Size:  555.4 KBName:  IMG_0746.JPG
    13. #113
      Man, that's not bad at all for weight. My 70 GTO is right there with you and it doesn't have the weight of the turbo components.
    14. #114
      Jan 2016
      Arizona
      I am pretty happy with the weight, especially with it being a long bed. Thank you!
    15. #115
      Jan 2016
      Arizona
Size:  537.6 KBName:  IMG_0820.JPG
      Other air cleaners were super restrictive and had the little metal insert in the end of it that I guess comes off and usually trashes the compressor wheel on the turbo. So I got rid of those. Since I am a little cramped for space I picked up these ďshorty turboĒ K&N filters and it definitely is breathing way better. The Turbo needs 1000cfm of air flow and in most cases the only way to do that is to run a turbo guard or a HUGE air filter. These arenít flowing that much. But theyíre much better than the others. Heat wrapped the pipes too.
    16. #116
      Chicago
      Such an awesome build !!!!
      marty-mj
    17. #117
      Jan 2016
      Arizona
      Thank you!
    18. #118
      Jan 2016
      Arizona
Size:  446.5 KBName:  IMG_1305.JPG
      A couple new things we are going to install. I will post pics as we do them.
      Turbowerx Exa Pump
      Maven turbo mounts
    19. #119
      Jan 2016
      Arizona
Size:  441.6 KBName:  IMG_1858.JPG
      New turbo mounts
    20. #120
      Jan 2016
      Arizona
Size:  396.5 KBName:  IMG_1869.JPG
      Exa pump mounted
