    Page 9 of 9 FirstFirst ... 4 5 6 7 8 9
    Results 161 to 179 of 179
    1. #161
      Jul 2015
      Winfield MO
      Installing fire supression and mounted shock reserviors
    2. #162
      Jul 2015
      Winfield MO
Size:  227.6 KBName:  IMG-0115.jpg
    3. #163
      Jul 2015
      Winfield MO
Size:  101.9 KBName:  IMG-0179.jpg
      - - - Updated - - -
      - - - Updated - - -
    4. #164
      Mar 2019
      Quincy MA
      This is by far my favorite build on this site. Also the first build I've seen with CA Chassisworks GStreet equiptment on it. Thank you for keeping us updated.
      Want to convert my 68 to a 69 Firebird custom. Won't spend a dime on pro touring mods until I am confident in the parts I will want so I'm making myself a build guide and timeline. Until then I'm going to make it more driveable. Power steering, disc brakes, lower, LED lights, fix interior lights.
    5. #165
      Dec 2015
      Arkansas
      Love that stance!!! Nice build
      '67 Camaro SS - Currently in build stage but making progress!
      **Brett**
    6. #166
      Jul 2015
      Winfield MO
      Last of the ac /heater lines finished air boxes, just have to finish inter fenders
    7. #167
      Jul 2015
      Winfield MO
      Finally got the engine/ trans on start up stand
    8. #168
      Sweet!
    9. #169
      Dec 2018
      Quote Originally Posted by UDOIT View Post
      Looks like you switched the valve covers between when the engine was in the car and not that it is on the stand. What valve covers did you switch to, as they look like they will hide the coil packs vs. the ones from SCA that wouldn't. If you are going back to the valve covers from SCA, where are you going to place the coil packs? Thanks!
    10. #170
      Jul 2015
      Winfield MO
      Scotts Hotrods makes the valve covers. We are trying to go with the hidden coil vc because it makes the package cleaner. A couple issues with using them is that it takes a certain coil and it is not a high performance coil. We had a clearance problem with the rockers which we have solved. (Not wanting to machine the cover), and not sure if the temp will affect then even though they are vented. Didn't like our options on mounting coils but if the hidden ones don't work we will probably make a bracket an mount them to the front chassis support bars
    11. #171
      Dec 2018
      Thank you! I am running the same valve covers that you had and was looking for a cleaner option as well. We have opted to go behind the engine, but it still looks a little funky with the coil wire and the way that it is routed.
    12. #172
      Jul 2015
      Winfield MO
      Does anyone make custom bolting for mounting front end sheet metal. I know notchead and Billet Specialities. They make it in Stainless but i thought someone made Titianum ones
    13. #173
      Metamora, Illinois
      Anvil offers a few titanium fasteners.
      https://anvilauto.com/collections/in...ts-and-washers
    14. #174
      Jul 2015
      Winfield MO
Size:  426.2 KBName:  IMG-0693.jpg
Size:  404.6 KBName:  IMG-0690.jpg
Size:  327.0 KBName:  IMG-0691.jpg
Size:  416.4 KBName:  IMG-0689.jpg
Size:  374.0 KB final assembly
    15. #175
      Mar 2019
      Quincy MA
      What are the boxes on the side of the firewall?
    16. #176
      Jul 2015
      Winfield MO
      Passenger side is the dry sump tank and the one on the driver side is a water/meth tank
    17. #177
      Jul 2015
      Winfield MO
      Final assembly just need to f inish installing the grill/headlights and interfenders
    18. #178
      Damn that's beautiful!
    19. #179
      Jul 2015
      Winfield MO
Size:  353.1 KBName:  IMG-1124.jpg
Size:  213.1 KBName:  IMG-1118.jpg
Size:  209.1 KBName:  IMG-1121.jpg
Size:  170.5 KBName:  IMG-1122.jpg
      [][attach=config]191208[/attach getting close on the wiring
