      Jun 2009
      Massachusetts
      1957 9 passenger Pontiac safari
      Out of the box tow vehicle-
      1957 Nine-Passenger Pontiac Chieftain Safari Wagon
      3,000 miles since completion...
      Block: NEW SBC Roller Cam block, dynamic balance to match new rods and crank, Speed Pro Hypereutectic with moly coated skirts, Comp Cams Flat Tappet Camshaft (slight lump at idle), Edelbrock Performer intake with Holley 600 cfm shiny carb, electric fuel pump, MSD HEI Ignition, GM Serpentine frontrunner kit, Engine painted 1957 Pontiac Green.
      700R4 transmission with toggle to unlock 1800 rpm torque converter, New drive shaft, New dual master cylinder, New coated brake lines, Rebuilt posi-rear end, new axles, hubs, bearings and drum brakes. Front and rear sway bars, New heavy duty springs and shocks including rear air shocks, Custom 18 gallon SS gas tank, new ss gas lines. Prior owner stripped and painted car in single stage OEM Carib Coral, Replated bumpers and trim, Stainless polished and straightened, New or restored emblems, NOS light lenses, Halogen head lights with proper relays, New front Corvette hubs with disk brakes, new bearings
      Power rack and pinion steering, Vintage AC, Custom 15” steering wheel, Custom gauges in stock locations including a new quartz clock. Under dash (mounted in original front speaker box) blue tooth, IPod feed and backup camera. New carpet, new OEM style seat covers and door panels and custom head liner with LED lights. New door handle and window cranks, new wing window frames and new window felts. All window glass replaced with original manufacturer tinted glass made in USA.
      Located in Boston area
      Asking $60k
      Larry Nirenberg
      '23 Mercedes S500
      '23 Corvette Z06
      ’62 Chevy C10
      Jun 2009
      Massachusetts
      Open to interesting trades
      Larry Nirenberg
      '23 Mercedes S500
      '23 Corvette Z06
      ’62 Chevy C10
      Jun 2019
      I ended up purchasing this Pontiac - I would like to have more history on the car if you don't mind. Do you know who painted the car and how long ago it was done. Thanks
