Results 21 to 27 of 27
Thread: Ryans 72 c10 build
08-11-2018 #21Registered User
- Aug 2007
- 645
I used Speed Engineering long tubes on my 68 C10 LS project. Fit great. I think about $300 shipped.
On different note I noticed that you filled the fire wall holes except the fuse block hole. I filled mine and then mounted the Painless fuse block about 1-1 1/2" from the inside of the firewall. Fuses still facing out. Then ran the front wiring harness right under the steering column hole and out the firewall just to the right of the steering column hole. Then down the frame rail to the radiator support. You can't see any of the wires when the hood is open.
08-11-2018 #22Registered User
- Aug 2007
- 645
Sorry about the bad detail. I ran the front harness over the top of the steering column.
08-12-2018 #23
