    Page 1 of 8 1 2 3 4 5 6 ... LastLast
    Results 1 to 20 of 152
      Sep 2009
      Port Richey Fl
      1978 Mustang II restomod
      I took this in trade a few years ago toward some of the labor on restoring a Mustang. This is what we are starting with. The hood scoop has to go. I have always liked the Mustang II and I plan on making this my driver.
      Rusty Gillis
      Former SS/FA & SS/GA NHRA National Record Holder
      Sep 2009
      Port Richey Fl
      I'm not sure what they were thinking or what they used to cut this hole in the hood.
      After Brian worked on it
      The hood was sanded down to bare metal and all the old scoop holes welded.
      It looked good before it was primed but it needs a lot of work
      After a little block sanding and bodywork
      I plan on using the Mach 1 scoop and once that comes in I will bolt it on and finish the bodywork. At this time the hood is low in front of the hole but the scoop should draw that up.
      I sprayed a couple of coats of epoxy to seal the bodywork.
      A had enough Slick Sand polyester primer for a couple of coats
      Block sanded with 80 and found one low spot that required a little filler
      Two coats of SPI Turbo primer
      The hood required a lot of work but I'm happy with it now.
      Rusty Gillis
      Sep 2009
      Port Richey Fl
      We have a new problem. This was filled with bondo. I had not planned on taking out the gas tank.
      The rust was cut out.
      Eleanor gas filler kit from Mustangs to Fear was welded in place. A gas filler neck from a 1968 Mustang was also used.
      Billet gas cap from Mustangs Unlimited
      Rusty Gillis
      Sep 2009
      Port Richey Fl
      I wanted a cleaner looking taillight panel so the Ford holes were welded and ground down
      The bodywork is finished on the taillight panel
      Scottrods rear bumper fits great. The original bumper brackets were cut off and two holes were drilled in the trunk for a test fit. Add a few more bolts inside the trunk and a couple on each quarter and your done.
      Rusty Gillis
      Sep 2015
      SW KS
      Awesome! Thank you for putting this up!
      Chris
      Sep 2015
      SW KS
      I see its a T-top car and has some Fox 4 lug ponies on it. What are your plans for the powertrain? Going to stay with the C4? 4R70W swap or Aod?
      Going carbed or fuel injected? I love these cars. My friend had a King Cobra with the mesh wheels, 302 and a 4 speed, and it was one of the first cars I rode in that truly scared me from a power / flimsy chassis ratio. I've loved them since then!
      Chris
      Oct 2015
      Looking good - Keep the pictures coming.
      Sep 2009
      Port Richey Fl
      We found a 8" rear from a 1965 Mustang. The spring perches are a little wider on the rear but we made it fit. I ordered a 1" lowering kit.
      I installed a Rod & Custom front suspension in my 1968 Coupe and upgraded to Baer brakes so I used the original ones that came with the kit on the II.
      The front fiberglass bumper was to wide and shaped wrong at the bottom
      I cut and taped a piece of aluminum
      Added three layers of fiberglass mat
      Removed the aluminum
      Still needs more work
      When I'm finished the valance and bumper will be one piece.
      I added 3 layers of fiberglass mat on each end and now all I have to do is fit the center piece and a lot of bodywork and I will have a one piece bumper and valance!!
      Test fitting the one piece bumper and valance
      I still have a little work to do to get it lined up to the fenders
      Rusty Gillis
      Feb 2013
      Berwick, South Louisiana.
      Cool project. Nice to see you building a daily driver like this. Subscribed.
      Oct 2015
      Cool. Great quality. Going to be nice.
      Nov 2007
      Dayton, Ohio
      Rusty, excellent project. I've been wanting to build a DD mustang II for several years now. Been looking for a good running 302 non T-top hatchback car. Had a 78 T-top car in the early 90s, didn't care for the T-tops. Want to go with a mild carbed 302 with 5-speed. Passed on a couple of cars so far this year, neither was currently drive-able. I'll be watching this one.
      Roger
      69 Mustang coupe, under construction
      2011 Mustang - DD
      https://www.pro-touring.com/threads/...ang-SuperCoupe
      Freedom Of Speed!
      Aug 2006
      Easton, PA
      you're managing to make a II look pretty good, nice job!
      my Dad had a '78 Mustang V6/4 speed, for a little while back in the day; bright metallic blue, white vinyl roof notchback, white vinyl interior with a blue rug. hideous. all that and terrible handling too!
      Keith C.
      Jul 2013
      St. George, UT
      I was getting all excited and then the thread ended. More!!!
      May 2011
      Brisbane, Australia
      Country Flag: Australia
      Great job on the bumper and front valance. The original monstrosity ruined the entire front end of the car. Yours looks right!
      1966 Plymouth Fury III
      Sep 2009
      Port Richey Fl
      Quote Originally Posted by 69stang View Post
      I don't like the T-tops but I'm stuck with them. This was somewhat of a driver when I got it but after sitting for a couple of years it didn't want to start.
      Rusty Gillis
      Sep 2009
      Port Richey Fl
      We had a few rust holes in the floor that were cut out and new metal added.
      Floor was sanded and epoxy primed black
      Because this has a T-top we are going to add subframe connectors and a roll bar from S&W. The roll bar was sanded and epoxy primed.
      Rusty Gillis
      Sep 2009
      Port Richey Fl
      The major bodywork is finished
      Two coats of SPI epoxy
      Block sanded and a little more bodywork
      More epoxy
      I block sanded again and sprayed white epoxy. I have decided on a color SPI Orange. It is a little darker in person
      Rusty Gillis
      Sep 2015
      SW KS
      Yes! I also spy 5 lug wheels!
      Sep 2009
      Port Richey Fl
      The fenders have been sprayed white epoxy almost ready for SPI orange paint then I decided to fill in the marker lights
      Ready for more primer. The wheels are off of Brian's 94 but the offset is wrong and the front cap won't go over the spindle
      I sprayed two coats of SPI epoxy primer on the body and roll bar
      I finished the bodywork and sprayed a coat of epoxy to seal it before spraying urethane primer
      The body has been block sanded and I sprayed a couple more coats of SPI Turbo urethane primer.
      Rusty Gillis
      Sep 2009
      Port Richey Fl
      The wheels and tires are will be using
      Rusty Gillis
