    Monroe, ct
    67 firebird headlight housing
    looking for the housing the lights get bolted to on a 67 firebird. I Can not find them and i do not think they re stamp them. Any info would help. Thanks
    Trevor
    Melbourne, FL
    Which part are you looking for?? #2 or #3 ?? Ames sells #3. Not sure if #2 is made aftermarket. I may have a spare on in my attic. I'll take a look and see. Right,left, or both?? I don't think it matter but I'll double check. You can also check over on the PerformanceYears site. http://forums.maxperformanceinc.com/forums/
    67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
    Honest dad that 455 on the side of the block is a serial number
    Jan 2007
    CT
    i think he needs the stamped steel housing that has the lights, bezel, and rings mount to. His are totally rusted out when we were putting it together.
    ________________
    Nick S.
    Gold/Gray 1967 Camaro
    Mountain Springs, Texas
    1957 Buick Caballero - huge project
    1946 Chevy pickup patina project
    Melbourne, FL
    Nolt a bad deal if he is close enough to pick it up.
    Monroe, ct
    You guys are the best thanks for the help
    Melbourne, FL
    Do you still need this item ???
