    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 43 of 43
    1. #41
      Question: does this sequential package come with a controller? Or is rev-matching, etc. a manual effort?
      Manual effort, but if you use a strain gauge on the shift handle, you can have integration with the EFI system. There are also companies that offer this integration with stock GM ECUs by means of an added box that goes between the ECU and coils. So based on input into that box it can cut ignition on upshifts. Downshifting and rev matching is more complicated.
    2. #42
      Yes, such a package also needs a high-quality gear position sensor. That's needed to deal with with dog interference, retry logic, shift complete indication, etc.
      One other thing the sensor can do is provide a gear indicator on the dash. For track use, it's easy to forget which gear one is currently in, as the sequential shift handle takes the visual / feel indication away since it's always in the same position when you go to initiate a shift (up or down).
      John Parsons
    3. #43
      Nov 2014
      East Tennessee
      Exactly. For that price its should come with a gear position sensor, maybe even with a 7 segment display.
      IMO, a ratcheting barrel cam shifter like that makes it hard to control the speed of the shift, which for a synchronized gear box is a real strain.
      For a dogged T56 this would be great, with the gear position sensor of course. Probably alot less expensive than an integrated barrel cam case
      Electrical/Mechanical Engineer
      1968 Camaro RS - Flat Black
