      Apr 2015
      cts-v brembo 4 piston brake swap
      I need swap info for the cts-v 4 piston caliper I've seen post on ls1.com post http://www.ls1.com/forums/f66/cts-v-install-w-pics-115446/ the calipers both bolt up on the same according to the post using the z06 rotor I would use the brake brackets from kore3 for the z06 6 piston and the z06 rotor as the above post used on the 4th gen camaro but in the rear can I get a 4th gen camaro drum in hat parking brake assembly and bolt the rear caliper to that or would a z06 parking brake assembly from flynbye.com be better I think there $385 kore3 also makes some kind of setup but they sell a rear caliper mount for like 140$ or a parking brake set up package when you select no caliper pad or rotor and just get the drum in hat setup it's like $750 I want to achieve a cts-v front and rear caliper with a z06 rotor and still have a e brake setup to stop if I have a line failure and suggestions anyone do a similar mod with oem parts the rear end on my car is a gm 10 bolt
      Aug 2013
      Alabama
      I was just researching the same thing! Would also like to know.
      Dec 2014
      Tampa, FL
      As long as you have the right spindles, your OK. Call the guy at kore3.
      Jul 2012
      Traverse City, MI
      First, use some periods. I cant read that without my brain hurting.
      Second, what car?
      Project thread - https://www.pro-touring.com/threads/...ouring-Project
      IG - @tc_chevelle
      Jul 2017
      CTSV Brembo Bakes
      HI: You may want to check out https://bigbrakeupgrade.com/. They offer complete kits or components for this conversion. I did this same swap (CTSV Brembo 6 PISTON FRT 4 PISTON REAR) on 1967 cAMARO. Keep in mind you will need custom wheels with over 1.77" caliper clearance.
      Oct 2012
      The Colony, TX
      Quote Originally Posted by 1967camarors View Post
      Hey 1967 Camaro - you have any pics of the brackets and install?
    Tags for this Thread
