    Results 41 to 60 of 71
    1. #41
      Central CA USA
      Baer did a conversion for us to convert to 14" rotors. The 15" rotors MAY clear 18" rims depending on the MFR of the rim. We possibly could have been OK but it was too close to risk it. Their conversion may not be a listed kit yet but they can do it. Have them look up what they did for Mary.
      Willwood has rear brakes that work, that is what Art Morrison sells.
      Here are the Baer 14" brakes on Mary's Camaro, Mary took more and better photos, I'll see if she has one of the brackets. I had to cut a flat on the GM cast aluminum knuckle but Morrison now does it for you. Mary's was the first customer unit, mine was the second.
    2. #42
      Mountain Springs, Texas
      Time to bump this up for some updates from David. My install is complete except the e-brake cables. I plan to use an E-Stopp. I am running Brembo brakes off a 5th gen ZL1 so I had to swap the hubs. Here's a couple of pics. The exhaust is also done, I ran 2.5 inch under the center section.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
    3. #43
      Dec 2009
      Carson City, NV
      Don
      Nice looking setup Don, who did the driveshaft and adapters? I need to get a drive shaft for my Chevelle and I am gonna need the same adaptors
    4. #44
      Quote Originally Posted by ChevelleNV View Post
      The Driveshaft Shop. Nice guy, easy to work with.
      Don
    5. #45
      Huntington Beach, CA
      Cool install David and Don!
    6. #46
      Feb 2011
      dallas, tx
      what lugnuts are those?
      Quote Originally Posted by David Pozzi View Post
    7. #47
      Central CA USA
      They are Summit brand. They are 4 to a package. Name:  image.jpg
    8. #48
      They are Summit brand. I'll look for a part number.
      What, no updates? I need to see how you routed the e-brake cables etc. I've used your build to help me get through the rest of the install, especially the floor and trunk mods.
      I have purchased similar lug nuts on ebay. Just search for the size you need, they are usually one of the lower cost options.
      Don
    9. #49
      May 2014
      Looking Good!!!
    10. #50
      Central CA USA
      We didn't hook up the E brake cables on Marys car. On mine, I may run them but don't have the brakes yet. If anyone contacts Baer for IRS brakes, they have it worked out, just tell them you want the same as Mary has. Her's are 14" with the R series calipers.
    11. #51
      Central CA USA
      Another note on something we have been dealing with. We loctited all the CV joint bolts and marked the heads with paint dabs. The inner left hand joint had a little more grease inside and we didn't get it all out of the threads the first time. Several bolts came loose on us on that joint only but we caught them in time. I cleaned the threads with carb cleaner and blew them dry and they are holding now. Just make sure you have everything clean when you apply the Loctite.
    12. #52
      May 2014
      Art Morrison IRS install, 67 Camaro
      David this is an awesome thread! I loved reading about the IRS in Mary's car and I can't wait to see yours come together!
    13. #53
      Central CA USA
      Thanks, I need to start a thread on my 67 build some time. It's been going pretty slowly but coming along. Nothing fancy, but hopefully it will be fast.
    14. #54
      May 2014
      Knowing the Pozzi reputation, I think fast might be an understatement David!! Hahaha
    15. #55
      Mine came fully assembled with the CV boots installed etc. Do I need to remove the boots and check all the bolts?
      Thanks again for your help David. You have saved my bacon quite a few times on this installation.
      Don
    16. #56
      Central CA USA
      I didn't pull the boots, I figure they are packed with grease. I pulled the CV bolts, washed out the threads on the flange with brake cleaner spray. I used red loctite and had good luck on all but but the left side of the diff , it kept working loose on us. Finally I bought stage 8 locking fasteners. They have a tab that sticks out to prevent turning, and a snap ring holds the tab. I glass beaded the threads so the loctite would grab them better, they come Nickel plated. No more problems. I only used them on the LH side of the diff.
      You must Torque and loctite EVERY bolt, including the steering link stud to the aluminum knuckle assy. Art Morrison does not torque them to final because they figure you will dissassemble to powder coat or paint them.
      Another tip on the lug bolt pattern. Art Morrison uses a Corvette ZR1 hub, which has a std old style 4 3/4" bolt circle. The std late model Camaro hub uses a metric bolt circle so any late Camaro brakes you use would need to have the bolt pattern modified to fit. They are very close, but different. Also the center hole register is larger on the Corvette unit bearing.
      Also you need to be careful if you change your camber setting. Changing camber will change the rear caster. Rear caster is the "clocking" of the rear knuckle looking at the side of the car. If rear Caster changes, the height of the toe links change and that greatly affects rear toe change as the suspension moves. The latest version of the installation manual should have the required caster specs. Measure by placing a degree finder against the caliper mounting bolts, or the underside of the calipers if you can find a flat area. Ask AME for a caster spec for the camber you are using.
    17. #57
      Mar 2012
      Looks like this:
      http://www.lateral-g.net/forums/atta...1&d=1457578298
      The rotor brake holes are larger, since the Camaro uses a 14MM stud and the ZL1 uses a 12mm stud. If you carefully open up the rotor hub register, you can make the rotor hub centric, which has no affect on the balance of the assembly. Kore3 made my radial brackets to put a Baer caliper on the Camaro 14.4" rotor.
    18. #58
      Mar 2012
      Oh and the Corvette is 5 on 120mm and the Camaro is 5 on 120.4MM (or something like that).
    19. #59
      The Camaro is 5x120 and the Corvette is 5x4.75"
      Instagram @projectgattago
      Dr. EFI
    20. #60
      Mar 2012
      Yeah, I am dyslexic.
      4.75" in MM is 120.65MM = Corvette pattern, with 12MM wheel studs.
      Camaro is 120MM with 14MM wheel studs.
