    View Poll Results: What gauges are you running?
    Voters
    168. You may not vote on this poll
    • Speedhut
      42 25.00%
    • Dakota Digital
      45 26.79%
    • Autometer
      59 35.12%
    • Classic Instruments
      4 2.38%
    • VDO
      3 1.79%
    • Misc
      16 9.52%
    Multiple Choice Poll.
    Results 81 to 100 of 100
    1. #81
      Sep 2014
      Sun City West, AZ
      Since, I am running the Holley HP EFI Compter on my 1989 Corvette, I thought about going with the Holley Digital Display. I decided not to because the intent was to get away from the OEM Digital Instruments and get back to real analog gauges so I went with Speedhut because you can customize the gauge to your specs. without any additional cost. Also, I had the Corvette Logo added to my GPS driven Speedometer, and the Tach. The custom dash work was designed and fabricated by JCG Restoration and Custom in Oxnard, CA
      Kenny Mitchell
      [email protected]
    2. #82
      Oct 2015
      Western Mass
      Was wondering about toeing in the idiot lights, for those of you with these newer electronic gauges, does the gauge light up when fuel is low or water temp is very high?
      Kenny, that's a nice looking setup above.
      '69 LeMans Blue Coupe, White Interior, Massaged .030" over 454, Super T10 4-Speed,
      Holley 4150, Pertronix Ignition, CompCams Xtreme Energy XS274S, 781 Oval Port Heads
    3. #83
      Sep 2014
      Sun City West, AZ
      Thanks for the comment. Yes, I Speedhut does offer the idiot lights on either some or all of their gauges. I elected to not have any idiot lights. I wanted to keep it simple.
      Kenny Mitchell
      [email protected]
    4. #84
      Oct 2015
      Western Mass
      The thing I like about SpeedHut is the various customizing options. I roughed up a couple of approaches in Photoshop to see the overall look. In the end, I opted for their white face with black markings since my Camaro is LeMans Blue with white interior and white hockey stripes. Also added a Camaro script in the two main gauges along with a color band redline on the tach. The nighttime color of the gauge faces was spec'd as light blue (see comment below).
      Here's a shot while trial fitting the insert. This is what I see through the steering wheel while driving. Its a big improvement on the stock layout. I might think about tweaking the angle of the two lowest gauges, but I'm not having a problem.
      Just recently got this installed, I have one minor gremlin to iron out... its the lights on background color for the gauges. I may have a bad inverter because when I turn on the lights, the pointers all glow nice and red, but the white face is supposed to be blue and its not lighting up at all. Hope to tackle that tomorrow. Calibrating the gas tank was challenging, but I got it done. Also reset the GPS speedo odometer to read what was on my original speedometer because MASS DMV checks your mileage once a year at inspection time. Wouldn't look good if I had next to nothing on the odometer when they have a historical record on file.
      I decided that everybody and his mother seems to have the OEM woodgrain trim on their '69 SS cars, so thats why I went with the carbon fiber look. I had everything dipped in the most realistic pattern we could find. That included the console trim panels and the soon to be installed grab bar pane that goes above the glove box. I think it ties tit all together and I've received many compliments at last weeks cruise night.
    5. #85
      Oct 2014
      DFW, Texas
      SpeedHut
      1972 Plymouth 'Cuda - Not LS-swapped, 5.7L Hemi [MS3 Gold Box], T56 Magnum 6-speed - 'Cuda Build Page
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
    6. #86
      Mar 2013
      Sunny Calif
      Multi function temp gauge NVU 68
      Currently installed NVU 68 CAMARO gauge set.
      Im setting up for occasional auto cross days and have installed both oil cooler with temp sensor and trans cooler with temp sensors but debating on where to cleanly mount up two more gauges. Overall keeping the stockish look of the interior and dont want out of place gauges to drown out the simplicty and clean look of the factory dash.
      Has any one set up the coolant temp gauge on a multi pole switch to be able to toggle between all three sources?
    7. #87
      Nov 2002
      Georgetown,TX
      My 70 Elco has a Dakota Digital VHX dash, with white faces and blue lighting.
    8. #88
      Oct 2015
      Western Mass
      I haven't installed any "idiot" lights yet but I'm going to use the 12mm dash panel lights pictured below for at least the Emergency Brake and the Generator. Any working idiot light needs a sending device. In truth, we add analog gauges because idiot lights are very often useless. My SpeedHut GPS speedo... I ordered it with built in directional and high beam leds. They are tiny, but they are right in front of me not out of sight. The SpeedHut fuel gauge has a built in low fuel led so when you calibrate the tank and set empty & full parameters the gauge will light up before it goes empty... supposedly ar 1/8th tank.
      The 12mm directional arrow units draw so little current that you could drive both the speedo directional and the somewhat larger and more graphic 12mm by simply tapping into the directional lines. Same goes for brights. I started off thinking I needed a slew of indicators, but I've been driving with this for two weeks and I'm having second thoughts about some of the indicators. The second image below shows a populated insert. I may actually put a Bluetooth capable radio in the "normal" position and use the left lower side for switches. I removed the cigarette lighter already and put in a dual port USB device that works great.
    9. #89
      Jul 2011
      Istanbul / Turkey
      Country Flag: Turkey
      Soooo in love with my Speedhuts!
      Being handsome is only skin deep. But Badass goes to the bone.
      Mert Celet
    10. #90
      Aug 2015
      NJ
      I went with the Carbon Fiber Autometer gauges. Love 'em. Only thing I had to mod was turn signal lights - used small leds and drilled them into the top of the speedo and tack housing. Never even notice they are there unless you are looking for them. Still under construction, but about ready to turn over to the upholstery shop.
    11. #91
      Dec 2008
      Detroit
      Speedhut
      Name:  Photo Sep 10, 3 46 49 PM.jpg
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Bowler Performance, Rushforth Wheels, ATS, Holley EFI, KORE3, Ridetech
      Project Motor City Madness
    12. #92
      Oct 2014
      DFW, Texas
      Name:  20171118-untitled shoot-016.jpg
    13. #93
      Sep 2014
      Sun City West, AZ
      Did anyone count up the different brand of gauges and see which brand was the most popular? Just curious. I think Speedhut may be the most popular brand.
      Kenny Mitchell
      [email protected]
    14. #94
      Apr 2007
      New Jersey
      Just wrapping up putting a Racepak Iq3 Street in my 67.
      Doug L.
      68 RS/SS Conv. LSA/T56.
      67 RS Coupe LS2/T56 named "NutKse"
    15. #95
      Oct 2016
      Alaska
      Speedhut Gauges
      I saw Speedhut mentioned, ordered 3 gauges. They have a large number of options available for many of the features.
      Type of bezel, needle, face colors, number fonts, sizes,etc. You can get a custom label on the face.
      I haven't made a final decision on the dash they will go in. Speedo is GPS. Quarter mile, 60 foot, other performance can be measured. Tach has adj red line and shift points.
Size:  58.7 KBName:  Speedo Night.jpg
Size:  60.1 KBName:  Tach Day.jpg
Size:  58.7 KBName:  Tach Night.jpg
Size:  59.6 KBName:  Quad Gauge Day.jpg
Size:  66.0 KBName:  Quad Gauge Night.jpg
      1968 AMX, 4.6L DOHC, narrowed 9" w/ 4 link, IFS,tubbed, caged
      1969 AMX, 388 stroker w/ blower, TH400
      1970 AMX project rust bucket
      Trike project w/ 4.3L V6, TH350, vette rear (V6ON3 planned plate #)
      Chopper hard tail project
      1984 Honda 750 NIB engine/tranny, begging for frame and wheels
    16. #96
      May 2013
      San Diego, CA
      Not too many Classic Instruments fans out there? Why? Anything other than just looks?
    17. #97
      Mar 2013
      Sunny Calif
      not shooting for concours resto - tons of pro touring mods - compatability for conversions - more data than my basic fuel, speed and idiot lights.......are the a few i contemplated when swapping out.
    18. #98
      Sep 2014
      Tampa, FL
      NVU custom gauges. Before and after below.
      No clue why they are upside down, sorry.
      67 Ford Galaxie
      5.0 coyote engine, 2650 supercharger, T56 magnum, 9" truetrac
      68 Camaro RS vert
      LS3/T56 magnum, 9 inch, Ridetech F/R, Baer brakes
      74 BMW 2002 Tii
    19. #99
      Mar 2013
      Sunny Calif
      nice im runnin NVU as well with they built in the tic toc tac in new retro style
    20. #100
      Oct 2018
      San Jose, CA
      All autometer pro white face in stock dash locations here.
      71 Camaro. Looks great and functions as you would expect.
      Never an issue.
      1971 Camaro - 406 / T56
      2016 Camaro SS convertible
      2018 Colorado 4x4
