    Results 1 to 3 of 3
      Mar 2013
      San Jose,CA
      spark plug recommendation
      i have a SBC 406 with dart eagle 215 heads.. mostly want be a street car with some auto-x in the future
      right now it has autolite AR133 plugs as per recommended by darts website but from what i understand these are more of a race plug and colder plug so foul out easily?
      ive been messing with carb/timing to get right with this new setup and afraid these may be playing a part in all this
      any of you have these heads and what do you run?
      autolite,ac delco, ngk?
      thanks
      Jan 2012
      NGK is a better plug IMO. What's the compression, fuel, rpm range, etc? Also what type of plug does it take( solid gasket .750" reach 14mm etc)
      Southern Indiana
      NGK , Denso, AC Delco are my preference.
      In GM I still like AC plugs.
      Now I have found that Motorcraft will interchange with the AC plugs.
      And never cause an issue also.
      Only car I run Champions in are Chryslers products that come stock with them.
      I pass on Bosch Platinums anymore and NEVER run Autolite, the fit nothing, are stock for nothing and honestly see no reason to run thwm.
      Now, I have had some luck running Bosch Supers in certain engines, even GM. But I still stand by my preferences.
      Lee Abel
      AFTERMARKET PERFORMANCE
