    Page 17 of 23 FirstFirst ... 7 12 13 14 15 16 17 18 19 20 21 22 ... LastLast
    Results 321 to 340 of 441
    1. #321
      Nov 2010
      Quote Originally Posted by Savage View Post
      Awesome build!
      I love the power plant and attention to detail!
      Looking forward to seeing this one on the track! Thanks for sharing!
      Thanks Jerry
    2. #322
      Nov 2010
      Quick update, applied some Cerakote to my spindles, came out amazing.
    3. #323
      They look great. I was looking at it to use on some bolts.
    4. #324
      Nov 2010
      Front calipers are done, these babies are monsters. The pistons are 2 1/4" in dia. That makes 4 square inches per piston, 16 square inches per caliper, times 1200psi line pressure equals 19,200lbs of force per caliper, times 2. That should be enough to stop on a dime, and leave 5 cents change.....Name:  20191207_162525.jpg
    5. #325
      They came out great! Did you have any trouble getting the powder in the tight corners, or did you try preheating them a little?
    6. #326
      Nov 2010
      No preheating necessary, just very low air pressure. Thanks Wayne..
    7. #327
      Oct 2018
      Phoenix, AZ
      Sweet work! How have you felt about the size of that oven? I'm not sure if it's big enough, but I'm also not sure what would be a size between that and a full-sized oven either.
    8. #328
      Sep 2011
      Southern Ontario
      I am no expert, but I believe you only calculate piston size on one side of the caliper, so 2 1/4" X 2 for area. That Cerakote looks awesome!
    9. #329
      Nov 2010
      A lot of people use old house ovens, bit I don't have the floor space for it. This oven was big enough to do my lower control arms and calipers.
    10. #330
      Nov 2010
      Don't know how that works...
    11. #331
      Nov 2010
      Chassis is complete, next is getting the engine and trans ready for paint...
    12. #332
      Nov 2010
      Getting the engine and trans cleaned up and ready for paint. It's a big PIA to get in all the nooks an crannies, using degreaser, Eastwood Aluminum prep ( acid base ) and lots of elbow grease. I tried media blasting with walnut shells, didn't even touch it, just bounced off. Hope to finish up this weekend.
    13. #333
      Sep 2013
      sw Kansas
      PITA! I believe I understand! LOL
    14. #334
      Nov 2010
      Engine and trans are clean, just final prep before painting. I 3D printed some plugs so I can remove the spark plugs and paint in the recess. Going to install a Trans Go shift kit before I paint the trans.
    15. #335
      Nov 2010
      Finally after weeks of cleaning, the engine is painted.
    16. #336
      Apr 2011
      Rosser Manitoba Canada
      Wow I was strolling down and seen that you had done all that work just to paint it black. I almost puked but then when I scrolled to the next pic I was aware that it wasn't the case. I remember a magazine article about a feature car where someone commented on the fact that a car had no BLACK anywhere on it. Apparently black shows a lack of imagination. (I Agree) Nice project!
    17. #337
      Aug 2016
      Waconia, MN
      Can't believe I hadn't commented on this build yet.
      Not a Mopar/Dodge guy but definitely a fan of excellent work.
      Love the fabbed spindles. Might have to try my hand at Cerakote.
      Engine looks great too.
    18. #338
      Nov 2010
      Quote Originally Posted by egoman View Post
      Quote Originally Posted by SonomaZ View Post
      Thanks Guy's
    19. #339
      Sep 2013
      sw Kansas
      Looking good.
    20. #340
      Sep 2015
      Nice, love the swepty's
