Page 17 of 17 FirstFirst ... 7 12 13 14 15 16 17
Results 321 to 332 of 332
  1. #321
    Nov 2010
    Quote Originally Posted by Savage View Post
    Awesome build!
    I love the power plant and attention to detail!
    Looking forward to seeing this one on the track! Thanks for sharing!
    Thanks Jerry
  2. #322
    Nov 2010
    Quick update, applied some Cerakote to my spindles, came out amazing.
  3. #323
    They look great. I was looking at it to use on some bolts.
  4. #324
    Nov 2010
    Front calipers are done, these babies are monsters. The pistons are 2 1/4" in dia. That makes 4 square inches per piston, 16 square inches per caliper, times 1200psi line pressure equals 19,200lbs of force per caliper, times 2. That should be enough to stop on a dime, and leave 5 cents change.....Name:  20191207_162525.jpg
  5. #325
    They came out great! Did you have any trouble getting the powder in the tight corners, or did you try preheating them a little?
  6. #326
    Nov 2010
    No preheating necessary, just very low air pressure. Thanks Wayne..
  7. #327
    Oct 2018
    Phoenix, AZ
    Sweet work! How have you felt about the size of that oven? I'm not sure if it's big enough, but I'm also not sure what would be a size between that and a full-sized oven either.
  8. #328
    Sep 2011
    Southern Ontario
    I am no expert, but I believe you only calculate piston size on one side of the caliper, so 2 1/4" X 2 for area. That Cerakote looks awesome!
  9. #329
    Nov 2010
    A lot of people use old house ovens, bit I don't have the floor space for it. This oven was big enough to do my lower control arms and calipers.
  10. #330
    Nov 2010
    Don't know how that works...
  11. #331
    Nov 2010
    Chassis is complete, next is getting the engine and trans ready for paint...
  12. #332
    Nov 2010
    Getting the engine and trans cleaned up and ready for paint. It's a big PIA to get in all the nooks an crannies, using degreaser, Eastwood Aluminum prep ( acid base ) and lots of elbow grease. I tried media blasting with walnut shells, didn't even touch it, just bounced off. Hope to finish up this weekend.
