    Page 21 of 80 FirstFirst ... 11 16 17 18 19 20 21 22 23 24 25 26 31 71 ... LastLast
    Results 401 to 420 of 1589
    1. #401
      Apr 2014
      Quote Originally Posted by windows View Post
      I'm betting that Pat irons his socks. Looking awesome, as usual.
      My wife does the laundry, but I might have to talk to her about ironing my socks ;-)
      Thank you and Merry Christmas to all!
      Pat
    2. #402
      Pat,
      Merry Christmas.
      I noticed a few pictures back that you are using the Tanks, Inc fuel pump module and fuel gauge sender. I also noticed the rubber gaskets that you used to seal against the tank.
      Do yourself a favor, order the cork gaskets and use aviation sealer. I had those rubber gaskets installed in my Cougar and they swelled within a month of being exposed to whatever gas was being sold in WI in June (e10?)...
    3. #403
      Apr 2014
      Pat,
      Merry Christmas.
      Andrew,
      Thanks for the heads up on the rubber gasket I'll look into swapping it out.
      I hope you have a great holiday and new year!
      Pat
    4. #404
      Mar 2012
      Lethbridge, AB
      i love how you did all the bent lines looks killer! lover the rear sway bar setup as well!
      Build Thread!!!https://www.pro-touring.com/showthread.php?88692-1971-Speedipus-Rex&p=925864&posted=1#post925864
    5. #405
      Apr 2014
      Quote Originally Posted by dangina View Post
      Thank you fellow mopar fan!
      Happy Holidays to you and yours!
      Pat
    6. #406
      Apr 2014
      Installed the II Much vent canister, starting with punching out a 2 ½” hole where there was a 1 ¾” body plug using a knockout punch tool. This is a clean way to put holes into steel panels. Then I bent a 3/8” S/S vent line running downhill to the two tank vent fittings. I step closer to starting the bodywork.
      Pat
    7. #407
      Jan 2012
      Pat,
      Merry Christmas.
      Do you have a link to the cork gaskets?
    8. #408
      Quote Originally Posted by 69 Charger 440 View Post
      Nope. I just called Tanks, Inc. and ordered them.
    9. #409
      Apr 2014
      Ok this is the last of the pluming work (for now ;-) Before I put all the tubing tools away I bent up the rear brake lines. As the rear has no brake line clips I made 2 weld on S/S straps to go on the U bolts and 2 S/S clips that I drilled and taped onto one of the 4 link mounts.
      Pat
    10. #410
      Jul 2010
      Clear Lake, Iowa
      you never cease to amaze me with the quality of your work Pat!
      Joe Adams
    11. #411
      Apr 2014
      Quote Originally Posted by ih8z28s View Post
      Joe, Thank you!
      Pat
    12. #412
      May 2010
      British Columbia
      What size s/s fuel lines did you use ?
    13. #413
      Apr 2014
      Quote Originally Posted by langleylad View Post
      I used 1/2" s/s tubing for both the supply and the return. I stock the 1/2" tubing and fitting where I work ;-)
      Pat
    14. #414
      May 2010
      British Columbia
      Quote Originally Posted by keepat View Post
      Pat
      That's cheating ! lol
    15. #415
      Apr 2014
      I put the charger on the rotisserie so I can finish the bottom and prime it. I also have a small floor repair.
      Pat
    16. #416
      Pat,
      You are an artist with the tubing bender! All that experience working on yachts is showing...
    17. #417
      Dec 2007
      Lombard, IL
      I haven't been on here in months, so when I logged on today, yours was the build I was most interested in looking at. I admire your details and creativity! Your work is really awesome!!
      Dan
      1971 Chevelle Maliboo Convertible 496/4L80E
      1956 210 2 door Sedan 8-71 blown 468/T400
    18. #418
      Apr 2014
      Quote Originally Posted by Zanie View Post
      Dan, thanks for tuning in!
      Pat
    19. #419
      Apr 2014
      Pat,
      Thanks Andrew! maybe my next car should be fiberglass like a Corvette ;-)
    20. #420
      Sep 2013
      sw Kansas
      Plenty close to the ceiling but all that matters is that it clears. Good to see the next step.
