Results 41 to 60 of 370
05-24-2014 #41
Gil,
Great looking 69! Another reason your headers hire the ground a lot is the shock absorbers are to soft for your ride height. The weight of a 455 is pretty high, and it takes really good(stiff) shocks to control all that weight. I hope you can also get the exhaust tucked up a bit higher with the mod you are planning. Not hitting the ground or your floorboards is a difficult accomplishment with so little room to work with. After you hang the new pipes, look into installing a "H" pipe or balance tube as close to the headers as you can, this will improve the sound and will raise your engines low end torque( like a 455 needs help with that!), but they do tighten up the long pipes,and keep them from moving around independently(swinging side to side) so you can keep tighter tolerances between your driveshaft and floorboards. Keep up the good work! And involve your young son in as much of your work as you can!!
Again, great car!!
