Results 1 to 20 of 56
01-13-2014 #1Registered User
- Jan 2005
- 37
LOTS of pro touring parts - BigStuff3, Holley UltraHP's, MSD crank triggers, z06 stuf
UPDATED:
Here is what's left! thanks everyone for their interest and their payments. Everything has shipped now except the coils/6Al's which I have not yet received payment for but a deal is pending.
2 front c6 Z06 rotors DBA Gold drilled and slotted front rotors for c6 z06, fitted up but never used. Have slight surface rust on them from sitting in a box, but guaranteed to be no big deal, just get some sandpaper and scuff, and run.
new $463 per pair, will sell for $250 OBO.
http://marylandspeed.com/dba-4000-se...06-p-2339.html
i had interest in the rotors but have not heard back. they don't look too pretty so I cleaned one up and here are some new photos. This is literally 3 minutes with steel wool and sandpaper to get the thin surface rust off. you can see the crisp lines and chamfers on the holes, and the lack of any grooving, these rotors only have a few dozen street miles on them before I took them off and traded the car in. They've been sitting in a box since.
the scratch marks you see are from 200 grit sandpaper cleaning off the surface rust, just surface scratches, not any kind of wear or cracks :
Rear sway z06 sway bars, 2 c6 z06, 1 c5 z06, i think i have a c6 front as well, asking $75 each OBO.
2 full sets of z06 shocks, one 5000 mile, one 60,000 mile, but still felt perfect. Asking $150 for the 5000 mile set, $100 for the 60,000 mile set.
c6 z06 intake manifold... this one is at your risk. It is perfect and totally stock, and should be fine, but it has aluminum chunks in it from a blown up motor. You MUST clean it out extensively or it could blow yours up. No damage though.
Asking $150 obo.
pair of c6 z06 seats, very good shape, will have to add pics, dark grey with the light grey center inserts and z06 emblems. Asking $1000 obo.
Also have a pair of new Greg Good ported/rebuilt LS7 heads, with new valves (ferrea exhausts), seats, guides, springs, etc. I don't think they are full tilt ported but have some short side and seat work and should be reliable and flow well.
I'll have to add pics but these are still at hk racing engines fresh from Greg. I don't have them at my house
complete Big Stuff 3 SEFI system with harness and crank trigger for SBC,
Asking $1500 OBO.
Still have the Moto Lita Cobra wheel, $200
Someone asked about the wheel backspace/offset, it is pretty shallow. The mounting face is probably about a knuckle width deeper than the rear rim of the wheel.
and the surge tank;
Here is a better pic of the 351W superformance shelby cobra surge tank; it needs to be cleaned up but here it is anyway:
also have 2 moroso surge tanks, new, asking $20 each, but probably not worth shipping unless you bundle them with something else,
a chevrolet water pump 2 v groove aluminum pulley, and a chrome distributor holddown.
Various small block ford motorsport and SVO intake and exhaust gaskets for big cylinder head windsors.
aluminum ford SVO water pump, windsor, low miles, $50 obo
painless wiring toggle switch panel and harness,
asking $50 obo
vintage air under dash universal unit, compressor, and wiring...
Borla and Flowmaster mufflers, almost brand new, some ARE brand new, all in 3 or 3.5" sizes. Two borlas are for their 3" oval tubing, which you can see in the pic. 1 pair borla 3" oval, 1 pair flowmaster 3" in and dual 2.25" out, 1 single borla 2.5", 1 flowmaster Y 3" to 2.25"
$50 each OBO.
Everything else is sold!
Also, I forgot to list a Superwinch 1500 which I had in my trailer, with switch and wiring harness, ready to go, asking $100 (they are $160 new but without the switch and wiring harness. All you have to do is bolt this in and hook up the battery).
finally, i have a set of 8 forged low mile JE pistons, I had them in a pump gas 447 inch chevrolet small block, I believe it was a 4.130 bore, but my stupid electronic calipers battery is dead, and I can't seem to find a proper mechanical one to take measurements. Anyway, it was in a stock deck height block with AFR heads. They were perfect when removed, but have been rattling around in a box so I have no idea if they are worth zero or $600.... I would sell for $50 obo, or will use them as office paperweights...
