    Results 1 to 20 of 34
      Dec 2007
      DSE fuel injection tank vs Aeromotive Phantom w/ stock tank
      As I'm going down the checklist of swapping an LQ4 into my 72 Nova, I'm finding out that everyone was right about a) the supporting parts will cost double the amount of a used motor and b) it's going to be probably twice expensive as you originally plan. [/venting to people who can appreciate that statement]
      I'm trying to stick to a fairly budget build, but am trying to keep my compromises to a minimum. I've waited 20 years to build this car and I don't want to skimp out on one area that's going to come back and bite me for being cheap. I don't have any crazy plans for the car other than I want it to be just as capable as my 99 z28. I want to be able to daily drive, carve up the mountains, road trip, and be able to do the occasional autocross with minimal fuss and/or concerns, problems, or breakdowns. Power will probably never get over 500hp, and will just be bolt on LQ4 power while the money tree replenishes.
      I'm about to tear my hair out trying to figure out what fuel system to go with. I have ruled out the easiest (?) option of an external in-line pump as I have read too many stories on here and LS1tech about having to constantly have a full gas tank to avoid starvation issues. If I'm wrong on that, please change my mind, but I'm currently scared I'll starve the engine doing simple things like matting it from a stop light or hitting a highway on ramp while I'm under a half tank. I don't want to fill my car up every half tank just to enjoy it.
      This leaves me currently comparing the Aeromotive Phantom and the DSE stainless fuel injection tank. I cannot seem to find any reviews of either of these tanks on this website. I found a few older DSE threads, but this sounds to be a different tank. I spoke with Aeromotive on the phone earlier today and told them my intentions with the car, and the rep I spoke with didn't sound too confident that the Phantom would be a great fit and that I'd still run into having to have a 1/2 tank of gas at all times, but I really want to find someone who has this system in their car as I don't love the idea of stepping up to the DSE tank (just over double the $$$).
      Can anyone help point me in one direction or the other? Does anyone have either of these systems? There's got to be a Camaro guy out there with one of the DSE tanks?
      Aeromotive Phantom
      http://aeromotiveinc.com/2012/11/phantom-fuel-system/
      DSE tank
      http://www.detroitspeed.com/1968-197...el-tanks.html#
      72 Nova. Just trying to make a modest little driver.
      Phil Collins build thread - 6.0 LS / T56 magnum
      https://www.pro-touring.com/threads/...or-all-my-life!
      Dec 2009
      Carson City, NV
      don't beat yourself up on this, bite the bullet and buy a ricks/vaporworks tank. its not much more than the DSE tank and has remote pickups so you wont ever have a starvation issue. I know the tanks are expensive, but you will never have to worry about it.....plus it uses a GM pump that can be easily sourced at a GM dealer if it were to ever go out
      Dec 2007
      Quote Originally Posted by ChevelleNV View Post
      I was afraid that was going to be the first response... I do love the fact it uses a GM pump though. I'm sold on the entire idea of the vaporworx tank, until I get to the price. I just got off the phone with Vaporworx and they mentioned that I'm going to have issues running a truck intake due to the fact that the tank is set up for a return less system and the truck has a return. Does anyone know an easy way to convert the truck fuel rails/intake manifold to return less style? Apparently I'm the first person putting a junk yard LQ motor in and contemplating putting in a gas tank that costs 3x as much as the motor did...
      Any body out there with input on the DSE or Phantom set ups?
      Apr 2012
      Woodstock, IL
      The phantom is great. What about using a Tanks Inc fuel injected tank setup? We've had good luck with that and minimal starvation issues. Same goes for the Phantom.
      -Dale
      SchwartzPerformance
      May 2011
      Chippewa Falls, WI
      get a baffled tank from rock auto with a intank pump, replace with walbro 255 or similar and run fuel line/return line. you can use the stock truck rails and regulator. That would be the cheapest setup that would work sufficiently.
      I went even cheaper and ran a sump kit with a external pump. I only have issues below 1/4 tank due to no baffles in the stock tank.
      Justin N.
      1966 Chevelle
      1992 GMC Typhoon
      1989 Jeep Wrangler CJ 6.0 Twin Turbo
      1981 Jeep CJ7
      Dec 2007
      Quote Originally Posted by Schwartz Performance View Post
      -Dale
      Dale,
      That's good to hear some backing of the Phantom. Do you have any cars built using the Phantom that auto cross? Tanks Inc does not make an efi tank for a Nova unfortunately. Unless you have availability to some, I cannot find that setup anywhere. I'd love to hear more about the conversions you've done using either of those.
      Quote Originally Posted by Typhoon1015 View Post
      I can't find one from Rock Auto for a Nova that's EFI ready. There are tons available for Camaro and most other GM models, but nothing for the 3rd gen X body.
      Jun 2010
      Deployed
      I agree, the tanks are top notch.
      1970 Camaro/DSE build
      Dec 2007
      Have you had any issues with yours at all? Do you have any pictures of what it looks like installed in the car from the rear? (maybe a weird question, depending on how it looks... just curious if it looks out of place and hangs down super low).
      Anybody else have anything to weigh in with? I'm surprised by the lack of response on the DSE tanks and Phantom setups.
      Cincinnati Ohio
      I have a ricks tank with vaporworks dual pick up. I can run the car with less then 5gal of gas on a autox and not have any problem.
      If you search my name, my build thread has pics of the tank.
      1972 Nova Ridetech, Forgeline, Falken Tires, Wilwood, Bowler Performance Transmission, Lingenfelter Performance Engineering.
      Newbury Park, CA
      Sorry I missed this thread guys.
      The DSE "Supertanks" use vaporworx products and technologies. Both DSE and Rick's make great products, but a conversation with both of them may help you decide what would be the better route to take.
      I do not like to disparage competitors on-line, but do take a close look at how the Phantom is sealed to the top of the tank. Also, if the OE's could figure out a way to make something cheaper and better than a fuel module, they would be the first to do it. Compared to any aftermarket company, GM's design and engineering departments has pockets that are far wider and deeper.
      Dec 2007
      Quote Originally Posted by Bad94 View Post
      Bad,
      LOVE your car - amazing. How noticeable is the gas tank while it's on the ground? It looks like it hangs quite a bit lower than the stock tank?
      I hope you don't mind, but here are the pictures I was looking at:
Size:  75.7 KBName:  11_21_021.sized.jpg
      Carl,
      I had started an email thread with you a little bit earlier this week and was the one waiting on pictures. I had actually been looking at DSE's non-super EFI tanks, as they a bit cheaper than the Rick's and weren't quite as much of a stretch on the budget. I can't seem to find much on those non-super tanks...
      Thank you for all responses so far.
      Dec 2007
      -Dale
      So to my surprise, it turns out that yesterday Tanks Inc announced they would be producing EFI ready gas tanks for the Nova's like they have been for the first gen Camaro's.
      With that being said, this is turning into a vaporworx vs Tanks Inc decision. I know the Vaporworx is the best of the best, and you get what you pay for... but do I NEED that? The $1000 difference in tanks is my front brake setup! I obviously haven't decided yet, but it's nice to have another option thrown in there.
      I'm off to search and read everything I can about the first gen guys and the Tanks Inc setups now... please leave feedback if you have any on that setup!
      http://www.tanksinc.com/index.cfm/pa...rod/prd437.htm
      Jul 2011
      Washington
      Im in the same battle as you are with my 71 nova also getting a lq4. Mine is getting a cam, heads, car intake, etc put on it though. Probably going to go with the tanksinc setup when it comes out also, I just hope it doenst get pushed back any further!
      Jun 2010
      Painted post NY
      How about the OEM gm fuel bucket mounted either with vetteworks or homemade mount?
      Not nearly as fancy as Ricks, but simple..reliable...cheap(er)
      Leon Reed
      1978 Trans Am
      LS1/4L60E
      my build..updated 11-21-13 https://www.pro-touring.com/showthre...8-TA-LS1-build
      Jul 2013
      Gilbert, AZ
      I'm surprised that Aeromotive wasn't too sure about their Phantom setup. I was at their booth at SEMA last November talking to them for a bit. They had a demo where the tank was about 1/4 full I believe. They tilted the tank to the side, basically starting the module sock assembly, and I think it was about 30 seconds till we saw the fuel pressure gauge start to flicker. Granted some of that fuel may have been from the return, but still, the guy sold me on it being great for a car that is driven hard. We'll see, for $450 I'm going to try it on the 67 Camaro I'm putting an LT1 in a few months from now. Seems like a very cost effective solution if it works.
      Dec 2007
      Quote Originally Posted by CampbellshotrodsAZ View Post
      I was kind of surprised/disappointed myself, but, I'd rather them tell if they have doubts instead of trying to just pick a sale by blowing smoke at me. I think my plan is to go for the Tanks Inc setup and see what happens. I'm pretty sure aeromotive makes a setup for your car that uses a tanks inc tank with their pump system.
      Jun 2018
      Phil, how did the Tanks Inc tank work for you? I'm getting ready for a Sniper EFI install, and trying to decide between Tanks Inc and the new Aeromotive Gen 2 Stealth tank with a Phantom fuel pump.
      Jun 2010
      Deployed
      Quote Originally Posted by sixgunsuperman99 View Post
      Bad,
      Carl,
      The super tank is a vaporworks style tank, based on the pictures I saw the quality is not as good as Ricks. However Ricks also makes a tank that used a Walbro pump just like DSEs cheaper tank. Regardless of the style, DSE and Ricks seems to be in the same cost ball park. Since Rick specialized in tanks, they get my vote. Both have outstanding customer service,
      i wouldnt even consider those other companies....
      Dec 2007
      Quote Originally Posted by 69NovaDude View Post
      It's.. fine. You can tell the gas sloshes around quite a bit in the tank as the gas gauge will swing by close to 1/2 (1/4 tank up to 1/4 tank down) tank if you get on either the brakes or gas hard. I typically don't run it below 1/4 tank as a result. I had to replace the fuel pump I got as part of the Tanks setup this summer as mine burned up. That said, I think that was a result of fuel pump relay issues I was having that caused the pump to short out rather than the tank killing it. My first pump was quite a bit noisier than the second so I'm not sure if I just got a bad pump or not, but again, I think that was the pump and not the tank. The Tanks setup works just fine for driving around town and cruising on the highway (what I do). If you want a hardcore performance option I'd look elsewhere.
      It's been a few years since I've kept up with available options but I remember Rick's released a non-stainless, every-man version of their setup a few years back that was in the $800-ish range. If I were to do it again with that option available I'd spend a few more bucks and go that route instead. I'm sure the scene has changed since I put my car together. As with everything, mine's not bad, but I could do it better with what I know now and what's become available since my build!
      Chicago suburbs
      I love Aeromotive stuff so I used their tank & FPSC. Long story short I now have a Rick's / vaporworx. I would never again consider a stock style stamped tank in a FI application.
