    Page 7 of 16 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 ... LastLast
    Results 121 to 140 of 305
    1. #121
      Oct 2011
      Excellent attention to detail there! I'm following along as I'm in the middle of an LSA / TR6060 (magnum hybrid) swap myself.
      Thanks! It’s what happens when you watch a lot of Bitchin Rides. LOL. I’m watching your build as well. Your basically rebuilding that engine!
    2. #122
      NJ
      Looking good! I like the detail work on the cover.
    3. #123
      Cincinnati, OH
      Engine and transmission glow up look awesome!
    4. #124
      Well it's paying off because that motor/trans/engine cover look killer! The all black accessories looks really good. I am probably going to steal that idea
      And yeah, I'm completely rebuilding it. New bearings, rings, bolts gaskets, etc. What better way to top off a newly rebuilt motor than an overdriven supercharger!
    5. #125
      Oct 2011
      Got the car back from the body shop. What was supposed to take a couple weeks turned into 7 weeks. Anyway I’ve been busy putting the front subframe together and the rear IRS. Currently working on brake lines.
Size:  361.3 KBName:  50B32024-0E86-438D-A0A3-B418572CC126.jpg
Size:  298.3 KBName:  F2EEF92D-C20E-44F3-AF5E-60B44B371D10.jpg
    6. #126
      Sep 2013
      sw Kansas
      Looking good.
    7. #127
      That looks nice. Glad you have it back.
    8. #128
      Oct 2011
      Do you guys think this is ok to connect the hard lines to master like this? Or do you think I need the 360 bends for more flexibility like in the stock Camaro hard lines?
    9. #129
      I'd put some spiral loops into the lines.
    10. #130
      Oct 2011
      Thanks Andrew. That’s what I thought.
    11. #131
      Jun 2012
      Golden Valley AZ
      I've always been curious about that. I'm guessing it helps with vibrations and keeping the lines from cracking due to stress at the fittings?
      - - - Updated - - -
      Car is looking awesome!!!
      John Rodko
      69 RS/SS Camaro.
      Heidts Pro G IRS w/ 3:90 gear, Heidts Pro G front
      6.0L LQ4 to be TT
      6 speed or 4L80E, that is the question..hmmm
      Future plans for full TMI interior
    12. #132
      Oct 2011
      I messaged Don about the issue and he said that it’s really not needed and I have enough bends in the beginning for some flexibility. He also said that the spirals allowed the factories room for adjustments because they had sloppy tolerances. Could have also been due to different masters, prop valves etc. Factory worker can just manipulate the line over a bit this way or that way.
      While trying to figure out the brake line situation I decided to start doing the sound deadening. Went down pretty easy aside for some paper cuts. Wear your gloves! I plan to use MLV next then closed cell foam as suggested on sounddeadenershowdown.com.
Size:  459.9 KBName:  17858E19-9198-4AD9-94FE-CDB0DA1CAA32.jpg
Size:  434.9 KBName:  2CB62285-AE9F-4A1E-913D-96B28F0CAA6A.jpg
    13. #133
      To be honest I’ve never seen a pro build use the loops in the brake lines. I used to use them but stopped a while ago. Maybe Donny will chime in. He's always got some good advice.
    14. #134
      Here is Mark Stielows latest build. No loops.
    15. #135
      Oct 2011
      Thanks Don! No spirals it is then!
    16. #136
      Oct 2011
Size:  319.3 KBName:  EB5C4813-0A96-412B-B2AE-34D0C8263DAF.jpg
Size:  358.7 KBName:  383E3768-3D3D-4646-A7A7-AA35D1ECE54E.jpg
Size:  283.2 KBClosed cell foam is in
    17. #137
      Aug 2015
      charlotte
      This thing will be silent! where'd you get the foam from?
    18. #138
      Jun 2012
      Golden Valley AZ
      Quote Originally Posted by slimjim View Post
      X2
      John Rodko
      69 RS/SS Camaro.
      6.0L LQ4 to be TT
    19. #139
      NJ
      That is awesome! Nice work on the insulation! You will definitely have the quietest interior out of everyone here! Can't wait to hear your feedback on it.
    20. #140
      Oct 2011
      Thanks guys!
      Here’s the link. https://www.ebay.com/itm/Neoprene-EP...4AAOSwCKdfjgO8
      It’s really cheap considering you get over 230sq ft which is way more than enough. The whole roll weighs maybe 30lbs. It’s very easy to work with because it can be stretched in multiple directions and it comes with the glue on one side so you don’t have to deal with any messy glue. This material is 1/8” thick and that’s what’s recommended to use from soundeadenershowdown. They also recommend to double it up on the floor and firewall. This material also acts as a heat barrier according to soundeadenershowdown. At this stage the car feels totally different. The butyl layer that we all use made it sound less hollow when I slam the door. But with this material basically almost everywhere the car feels really solid. When I slam the door, all you hear is the latch closing and that’s it.
      I’m currently finishing up the Mass loaded vinyl layer and luckily saved the backing paper from the CCF to use as a template for the MLV this is making the project go much faster as you don’t need templates for the cutouts. MLV is much harder to work with because it’s very dense and bends only in one direction at a time. Also the glue I’m using HH-66 is very messy and smelly (like acetone). I’m probably getting high from it LOL.
