    Results 1 to 14 of 14
      Jan 2010
      Pine Plains, NY
      New Hooker Blackheart LS-swap header back exhaust
      Hey Folks, Has anyone done any research on this exhaust coming out from Holley?
      HOOKER BLACKHEART LS SWAP HEADER-BACK EXHAUST
      1967-1969 1st Gen GM F-Body 3" 304SS LS Exhaust w/X-Pipe and Mufflers without Resonator, For use with DSE (Detroit Speed, Inc.) Subframe & Suspension
      PART# 705013109RHKR
      Looks pretty sweet! What are your thoughts??
      Quote Originally Posted by nickburns View Post
      PART# 705013109RHKR
      I don't have direct experience, but many people on other forums seem to really like the fit. One point to consider is that exhaust is made to work with the entire Holley swap system, mounts, headers, etc...
      Dec 2008
      Detroit
      If it fits as well as the A body kit does, you should be in good shape. I did use their mid length headers in my application also.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Apr 2013
      I have the Blackheart LS swap headers in stainless from Holley in a 69 Firebird convertible with a 2004 GTO LS1 along with their engine mounts, these are the mid length units and the fit, form and function is all of what one could ask, very well engineered. Sub frame is stock with DSE upper and lower A arms, 2" lowering springs. Very pleased with my purchase.
      My header back system is Flowmaster w/single crossflow muffler, 2-1/2" stainless mandrel bent w/ H pipe. Nice throaty rumble and easily tolerable.
      Tim john---
      May 2011
      Hendersonville, NC
      Looking at the installation instructions, you will have to modify (cut two holes) in your trunk to get it to fit properly.
      Jan 2010
      Pine Plains, NY
      thank you guys for the reply, it looks like its all preorder and will be out in May.... I will print out the directions now. Any other ideas please feel free to throw them at me in a PM!
      Jan 2010
      Pine Plains, NY
      I have a notched Ricks fuel tank for the mini tubs... I wonder if that would be in the way if I have to notch the truck......
      Dec 2009
      Las Vegas,Nevada
      Bringing this back up again. Has anyone installed this exhaust system on a first gen Camaro with DSE rear suspension. If so, how was the fit.
      Are there any other kits out there built for a DSE equipped first gen Camaro that is bolt in or at least minimal fabrication. Welding is not a problem. I would like to find something that would be minor cutting to fit then clamp and or weld together and cost less than what a custom shop would charge for a custom built exhaust system.
      Feb 2011
      dallas, tx
      Quote Originally Posted by robert worl View Post
      Yes. fit is amazingly good. You will be very happy.
      Dec 2009
      Las Vegas,Nevada
      Any one with this exhaust system on a first gen Camaro? Could you get me a center to center measurement between the two pipes at the inlet side of the X pipe where it connects to the headers.
      I would like to know how close they are to fitting my headers. My headers are from stainless works and most likely have a different spread than the Holley headers this exhaust system is designed for.
      Thanks, Robert
      Last edited by robert worl; 11-23-2019 at 09:01 AM. Reason: Additional information
      Nov 2016
      Sulphur, La
      Thanks, Robert
      I'll try & get that for you.
      Dec 2009
      Las Vegas,Nevada
      That would be great, thanks
      Nov 2016
      Sulphur, La
      25 1/2" from outside to outside. Mine is a little out of round so it may be another 1/8" larger without that flattening.
      Dec 2009
      Las Vegas,Nevada
      Thanks, I should be getting my motor back from the shop this week. I will bolt the headers on and compare this measurement to my installation. If it’s close I will be purchasing the X-pipe from Holly then fabricate the rest of the system in 2.5” stainless to go up and over the axle.
      thanks again.
