    Thread: Tires
      May 2018
      Tires
      I am just wondering if what kind of tires is best for Pro-touring truck? Are tires like Toyo Tires' Proxes S/T highly recommended?
      Feb 2010
      El Segundo, CA
      Quote Originally Posted by Toxic38 View Post
      If a tire is good for Pro Touring cars, then it will generally be good for a Pro Touring Truck also. There are many good brands. I am partial to Michelin.
      Nov 2016
      Sulphur, La
      Typically for trucks I find that I need to pick sizes and then work my way through what is offered. Not as many choices for the OD normally required on a truck.
      Aug 2017
      PC Beach, FL
      Weight ratings are also important. A lot of good performance tires will not be rated for a 4K+ lb truck. I run a 295/45/18 Nitto NT05 which was designed for a truck with a 2469lb XL load rating.
      2000 Silverado RCSB
      Built 6.1L / Kenne Bell 2.8L / 4L80E / Suspension
