]Here are additional pic of what I did. They supply you with the U shaped bracket. They say your supposed to connect it to one side (the side that’s bent) this bracket is for a flat firewall. The Camaro firewall is not that flat especially in the area where the tranny tunnel meets the firewall. So I cut the bracket in half and put it on both sides.
Attachment 175720
I also trimmed that piece (circled in red) because it was hitting the upper cowl. With the unit level, I have about 3” between the top of the unit and upper cowl. The unit is 11” wide with the bracket so you can measure how much room you have with a stock dash.
Attachment 175721
The unit sits 12” from the floor(not sure why the image is flipped upside down?). Because I’m using the Mercedes dash, the unit is completely hidden behind the Mercedes dash. It also does not interfere with the Mercedes glove box. There’s actually a pretty decent size gap between the ac unit and the back of the dash which should allow for plenty of room for the ducting and wiring. I welded in the bolts (provided) to the firewall for attachment of the unit.
Attachment 175722
As far as the evaporator and condenser, they specifically sent me that for a 69 Camaro, the hard lines come prebent and fit really well. No mods needed to be made for that.
I haven’t powered up the unit yet so I can’t say anything about that. I will not have any AC/heat controls in the dash. I will control the unit via an iPad that will be mounted in the dash. I will not have any physical controls. It will work through their Bluetooth app. The only reason why I chose the restomod air unit is because they have an app. There are plenty of other options out there (cheaper options) for AC units. I chose the restomod unit ONLY because of the app.
