18 x 8 1/2 on 69 Camaro front?
I'm looking for new wheels for my 69 Camaro. I currently have Billet Specialties Ventec 17 x 8 with 4 1/2 backspace and 235/50x17 Bridgestone tires all around. The car is lowered with Ridetech coilovers in front and Hotchkis with 1 inch lowering blocks in rear. Ground to bottom of fender lip is just under 24 inches front; 24 1/2 rear. I run negative 1/2 degree camber in front to stay away from the inside fender lip due to the 4 1/2 backspace; it should be 4 3/4. The inside of the fender has been "clearances" with a hammer and the top fender bolts removed. It still rubs occasionally. Rear clearance is fine.
I'm looking to go to 18 inch wheels. I'd like to go 8 1/2 wide in front. Is anyone running a 8 1/2 wheel in front? What backspace are you using? My subframe is stock with Ridetech strong arms and coilovers.
Thanks for any input.
Joe
Billet Specialties Fender Bolts flush mount
Billet Specialties makes the bolts to buy for the front fenders:
http://www.billetspecialties.com/stainless-pro-bolts/
Not cheap, but worth it.
