Installing fire supression and mounted shock reserviors
Printable View
Attachment 177738Attachment 177737
- - - Updated - - -
- - - Updated - - -
This is by far my favorite build on this site. Also the first build I've seen with CA Chassisworks GStreet equiptment on it. Thank you for keeping us updated.
Love that stance!!! Nice build
Last of the ac /heater lines finished air boxes, just have to finish inter fenders
Finally got the engine/ trans on start up stand
Sweet!
Looks like you switched the valve covers between when the engine was in the car and not that it is on the stand. What valve covers did you switch to, as they look like they will hide the coil packs vs. the ones from SCA that wouldn't. If you are going back to the valve covers from SCA, where are you going to place the coil packs? Thanks!
Scotts Hotrods makes the valve covers. We are trying to go with the hidden coil vc because it makes the package cleaner. A couple issues with using them is that it takes a certain coil and it is not a high performance coil. We had a clearance problem with the rockers which we have solved. (Not wanting to machine the cover), and not sure if the temp will affect then even though they are vented. Didn't like our options on mounting coils but if the hidden ones don't work we will probably make a bracket an mount them to the front chassis support bars
Does anyone make custom bolting for mounting front end sheet metal. I know notchead and Billet Specialities. They make it in Stainless but i thought someone made Titianum ones
Anvil offers a few titanium fasteners.
https://anvilauto.com/collections/in...ts-and-washers
Passenger side is the dry sump tank and the one on the driver side is a water/meth tank
Final assembly just need to f inish installing the grill/headlights and interfenders
Damn that's beautiful!
Attachment 191204Attachment 191205Attachment 191206Attachment 191207Attachment 191208
[][attach=config]191208[/attach getting close on the wiring
