x2 Keep up the good work. This has always been a cool build to me
Printable View
very cool build.
Incredible engineering. Great build!
Very cool build. Mad skills!
Great SolidWorks modeling... subscribing to this and EAGERLY awaiting updates/progress :D :D
I have been following you on your blog,and probably since you started building this car..you where one of the first to report from scandinavia about pro touring cars.
Wow! I like the way you are building the parts. Keep up the nice work!
Robert
Nicely done. Looking forward to more updates!
As a 74 Firebird project owner, you're blowing my mind, man!
I can't say I've seen a De Dion axle under a pro-touring car.....what a novel idea.
Have you considered a Watts link rather than the panhard rod to locate the tube?
Great fabrication, way out of my league....very interesting project!
Good Lord, this car is insane. Beautiful work so far.
-matt
Wow! What a feedback I got here! :lol:
Thanks for all the comments, that really boosts my motivation!
Yes, I've considered a watts link. However, the car will be quite stiff (our roads are much better compared to what I've seen in the states and I'm more into performance than comfort) and won't have much more than +-1,5" travel. I won't gain very much with a watts at that short travel. It's also much easier to get a low roll center with the panhard.
Thanks for the cred! I was quite early with it but it also took much longer than I expected for others to pay attention to the "trend" and the serious builds are still easily counted on two hands (at least Firebirds...).
I might be able to offer some real CAD-p0rn later....:smoke:
Latest pics! Uploaded them yesterday so I could show them here :)
https://static1.pt-content.com/image...7600x270-1.jpg
The dedion is finished for test fit in the car (it's just spot welded - welding it after I know it fits).
https://static1.pt-content.com/image...9600x387-1.jpg
https://static1.pt-content.com/image...8600x415-1.jpg
There are alot of funny cut angles to the tubes. Instead of milling them in the correct angle (some tubes meet up to three others, so that means three different cuts/mills), I'm printing the circumference from Solid Works and cut it with a angle grinder instead. Tadaaah - 1 minute instead of 20 mins in the mill...
https://static1.pt-content.com/image...6600x450-1.jpg
The ends of the dedion are also done. By put shims between these and the dedion I'll be able to adjust toe.
https://static1.pt-content.com/images/noimg.gif
Yeah, I know. My TIG-welds aren't showstoppers. They do the work, but I'm very new to tigwelding...
https://static1.pt-content.com/image...1600x450-1.jpg
https://static1.pt-content.com/image...0600x450-1.jpg
The ends are seen here. Haven't had time to mount them IRL yet.
https://static1.pt-content.com/image...t600x295-1.jpg
Well this is an insane build. Alot of stuff which i can't understand making it all the color. Good luck with it, and what part of Europe are you in? I am located on this part of the earth at the moment too
I live in Sweden :)
Latest thing is that the lincoln hubs has been modified for the porsche bolt pattern.
Stock hub;
https://static1.pt-content.com/image...2600x450-1.jpg
Of course, the hub was too small, so I had to add some extra material. There for a ring was made;
https://static1.pt-content.com/image...3600x450-1.jpg
The ring was heated and the hub was freezed to simplify the pressing...
https://static1.pt-content.com/image...4600x450-1.jpg
Take a deep breath, get the ring and put it in the press. After that, run and get the hub from the freezer and throw it on top of the ring and start pressing as fast as you can... I actually had to make three rings - the first one went wrong so I had to cut it of with the angle grinder...
https://static1.pt-content.com/image...5600x450-1.jpg
Tadaaah!
https://static1.pt-content.com/image...7600x450-1.jpg
Hub after a while in the mill... Now there's BMW/GM and Porsche-pattern. There's also the possibility of running center bolt with both BMW/GM and Porsche. A Volvo/Lincoln pattern could also easily be added in the future if I want to...
So, finding new wheels in the future won't be a problem, haha...
https://static1.pt-content.com/image...1600x337-1.jpg
Finished with a little paint on it;
Of curse, I just HAD to try it on the wheel!
https://static1.pt-content.com/image...8600x450-1.jpg
(It's a front wheel. The rear wheels has 3,5" lips)
Inside;
I glass blasted the uprights and coated them with one layer of clearcoat to have the new-look lasting a little longer.
https://static1.pt-content.com/image...2600x361-1.jpg
I made a couple of bushings for the lower holes in the uprights;
Brake cooling also had to be done before mounting the hub in the upright...
Mounted;
BTW. Is there anyone who is willing to do me a BIG favor by receiving some smaller parcels (probably 6-10 parcels with fuel pumps, filters, fittings and other smaller parts) from ebay and them repacking them into a new, bigger box and then ship them to me in Sweden. That way I just have to pay one shipment and not ten...
You must have paypal so I can transfer money for shipping and handling...
If you willing to help, send me a PM.
PM Inbound.
-matt
New update...
The center bolt hubs are done.
https://static1.pt-content.com/image...9600x450-1.jpg
Detail view of the center bolt axle. Pretty much fabrication in this piece. All handmade, no CNC (wish I had one though...)
Exploded view. The left thing is supposed to be the half shaft. Then there's washer, center bolt axle, fixing ring between axle and hub, center ring for the wheel (since porsche has bigger holes than Lincoln) and a locking ring to prevent things from falling off.
https://static1.pt-content.com/image...0600x157-1.jpg
Finished! Next thing is to test fit the axle in the body. I can't wait! :) I feel like a child on christmas eve, haha.
looking good!
