2nd generation camaro parts
I am beginning a Pro-RestoMod project. Just completed the dis-mantling of the car. have may okay to real good conditinparts i would lik to sell and pass on to someone that needs them. This is what I have . i AM OPEN TO TRADES, SWAPS, ETC. for things that I will need in the future.
a. (1) - 327 small block, 2 bolt, cast iron from a 69 Chevy car, rebdild started never cmpleted, new heads
b. (1) - 327 small Block, 4 bolt??, cast iron, froma chevy truck, never rebuilt
c. (1) - 307/327?? small block, 2 bolt, cast iron
d. (1) - Turbo 400 with deep pan.
e. (1) - Camelback head - original from about 1968
f. (1) - Radiator Support Bracket - real good condition
g. (1) - Front end subframe, w sterring assembly and disc brakes real good condition
(1) - Includes Rancho 2 drop coil springs
h. (1) Gas Evap Canister - good, do not know if it is functionai
i. (1) - HVAC System parts good, most all parts including original compressor (needs rebuilding) and condenser coil
j. (1) - Heater System okay, core condition unknown
8. k. (1) - Vacumn Boost Unit w/ large master cylinder for rear disc brakes good
9. l. (1) - Gas pedal - good
m.(1) - Steering Column standard good with out steering wheel
1 n. (1) - Original Steering Wheel
0. (1) - Driver Seat good, broken upper post
p. (1) - Passenger seat - good
q. - Interior Door Panels, pvc panels, some white, some black, all panted black years ago.
C r. (1) - carpet, black loop good, after market replacement of 20 years ago. one hole near dimmer switch hole.
1 s. (1) - Dash Instrument Cluster good and working last time driven. mounting holes broken off, top half of holes
1 t. (1) - Dimmer Switch good and working last time driven
W u. (1) -HVAC Control Panel good, mixer bracket is broken, have extra bracket needed for repair.
2 v. (1) - Rear Window Glass, good, some scratches from sander at edges, minor, can be buffed out. has decals
2 w. (2) - 15 x 7 Wheels - Keystone, Classic Black, good
2 x. (2) - 15 x 8 Wheels - Keystone, Classic Black, good
y. (1) - 12 Bolt Rear End with one new Axle, disc brakes from 1980 firebird - good - Sold
z. (1) - Misc Engine Parts
a. 600 cfm Carter Carb - good
b. Edelbrock High rise Value covers (1 set) - good
c. Square Bore Aluminum manifold
d. cast iron manifold
e. Edlebrock triangle air cleaner
f. Alternator
g. Power Steering pump.
2 aa. (1) Drive Shaft Turbo 400 to 12 Bolt, steel, - good
bb. (1) Hood standard, 2 small dents, 8 holes from fiberglass scoop, holes have been filled years ago with bondo.
cc. (1) all of the electrical system.
dd. (1) some trim - good condition for 40 years
I have everything that would have come off the orignal car, except some parts for the engine
