What sort of input signals does that fan controller need? A PWM signal or just a temp sender?
Don
Printable View
They are a PWM controller, designed for EFI applications where the ECU controls the fan speed.
Otherwise just use a temp switch to power a relay when the fans are needed (IE no speed control, just on or off).
Don it needs a PWM signal. For your reading pleasure...
https://www.yellowbullet.com/forum/s....php?t=1350410
https://www.pro-touring.com/threads/...fan-controller
http://lateral-g.net/forums/showthread.php?t=40215
As was said above. It's literally the same controller at the C6 Corvette controller. So it needs a PWM- signal.
You ever have one of those, "crap, I didn't even think about that!" moments?
What's the difference between - and + PWM signals? Asking for a friend with a Spal fan and a Holley Dominator.
PWM- pulses to ground. PWM+ pulses to positive.
Thought it was more complicated than that.......
What happens if you send it - and it wants +? System in question is functioning, can't remember what I set it to, do not have laptop to look.
