View Full Version : control arm set
Fras
06-20-2013, 05:33 PM
I have a 68 camaro with Heidts tall 2" drop spindles and QA1 coil overs. After getting screwed over by the last builder, I'm on a tight budget trying to finish this thing up.
The stock control arms are beat up pretty bad. Can i just order some tubular control arms with the stock geometry like Summit has for $500. Or do I need to spend the $1200 ish on the other stuff?
This will not be on the track much, if at all, and more of just a street car. Thank you!
Randy Fras
Smoker03
06-21-2013, 07:31 AM
With that spindle, you may want to check for bind in the balljoints, you may want to complete the setup with the heists arms which are designed to work with their spindle
Fras
06-21-2013, 11:46 AM
Thanks for the advice. I called Heidts and they said the geometry on their tubular arms are the same as stock.
