69lsxamx
06-12-2013, 06:09 PM
Prices don't include shipping cost. I can send pictures of everything if needed.
93 Cobra wing $50.
Fuel rails for 4.8, 5.3, 6.0, chevy and GMC engines $40
Flywheel for 4.8, 5.3, 6.0 Chevy and GMC $30
Throttle body for DBW 4.8, 5.3, 6.0 Chevy and GMC $50
Chevy and GMC truck intake 4.8, 5.3, 6.0 $75
1969 amc amx brake calipers $30 each they need rebuilt both of them leak
69 amx dash pad $40
AMC timing cover and oil pump $50
AMC 727 Transmission $150
LS computer and harness $525
C&L Intake elbow for fox body mustang $35
MSD Rev limiter pills, $15, 9100-9900 RPM's
MSD REV limiter pills $15 8100-8900
spec stage 2 11 inch clutch for ford very low miles zero heat spots. $250
Ford modular bellhousing for tremec transmission's $300
03/04 cobra aluminum flywheel $100
New ford racing 4.10 gears for 8.8 rear end $150
2003 Ford F-150 ABS $50
2003 F-150 windsheild washer fluid jug $25
2003 Ford Lightning Intercooler Coolant Tank $40
4R100 Transmission Input shaft $50 from 2003 lightning
F-150 battery Tray $25
1988 or 89 mustang Gauge Cover and light switches $40
V-8 explorer headers $45
V-8 explorer flywheel $15
Moser C-clip eliminator For ford 8.8. One new one is used. $80
87-93 mustang lights one new one used New one is for right side $20. Used one is for left side $10
Fox body mustang 5.0 injector harness. $40
Fox body mustang fog light $25
2 right side headlights for 87-93 mustang, $15 for older looking one, $20 for the better one
Oil cooler from a 95 cobra will fit other 5.0 cars $30
5.0 mustang water pump pulley and crank pulley $10 each
Exhaust manifolds for 4.8, 5.3, 6.0, chevy and GMC truck engines $50
Transmission pan for 4R100 ford $30
Fox body mustang stock radiator $45
Ford f-150 wheels 2 16x8's, 2 16x10's $150
Fox body 5.0 5 speed bellhousing $50
3 tires 275/50/20 Goodyears $30 each or $75 for all 3
Troy built pony riding lawn mower about 4 years old 42" cut runs good but needs deck worked on $200 OBO
4l60e transmission $200
13x7 4 lug steel dirt track wheels and hoosier tires $15-50 each depending on condition .
mustang clutch quadrant and firewall adjuster I don't remember the brand $15 each or $25 for both
4 quad shocks $5 each
Quad shock mounting bracket left and right $5 each
https://static1.pt-content.com/images/pt/2013/06/309265_401943579860422_287173318_n_zps82-1.jpg (http://s269.photobucket.com/user/mustangracer11/media/for%20sale/309265_401943579860422_287173318_n_zps82f1ea1a.jpg .html)
93 Cobra wing $50.
69 amx dash pad $40
