View Full Version : Input needed: Swapping in a 4.6L stroked superchagred motor into a 1969 Fastback
s4dustin
06-11-2013, 08:08 PM
Ok gents, found myself in an interesting situation.... just bought a 97 mustang that is built! Good for about 700 hp with the boost at 10-12lbs...The driveline is brand new....and built right. I was thinking of keeping it for summer then selling it as it is a convert, but then got to thinking about swapping the driveline into my 69 Fastback.....the trans is a built Art Carr...and a great rearend/axles.....has anyone done a 4.6L swap into a classic Mustang? I did a LS swap into my 68 Camaro.....and I am more familiar with Chevy.....anyone have any insight on this....did a search, could not find much......anyone?
Todd in Vancouver
06-11-2013, 09:00 PM
Have no idea but I'd like to add my encouraging words and say yes I'm into following that build thread.
Whistler
06-11-2013, 09:49 PM
The 69s have a little more room between the shock towers than the older Stangs but it's still a really tight fit. It's a swap that has been done many times before so all the parts you'll need are available but it's definitely not the walk in the park that an Ls1/68 Camaro is. Good luck with it, it'll be an awesome car when you're done!!?m
s4dustin
06-12-2013, 06:09 AM
77418The LS swap was not bad...but this engine is big.....not my first choice per say, but 650-700hp.....and it is for the wife's car....may have to do it....
riles
06-12-2013, 10:59 AM
I think one of the users on here did it, maybe Schwartz Performance.
Also sent you a pm with info.
Daves69Coupe
06-12-2013, 12:16 PM
lots of these swaps have been done on 69stang.com. I know at minimum you have to swap out the shock towers to the notched big block kind but I would ditch the towers all together and go with a Mustang II style front end.
06-18-2013, 03:12 PM
We did a 5.0L Coyote swap, not bad at all. Wiring is going to be the only problem for you- eliminating wires unneeded, and tuning those things out! Just like any EFI swap.
Kevin Tetz did a supercharged 4.6L in his '66 using our chassis, you could do some searches on that and see what other parts he used??
-Dale
